NX4510 range lever.
/ NX4510 range lever. #1
rhunt
aiken sc
kioti nx4510 hst
While moving some logs around yesterday the range selector lever flopped around so now I could not get out of low range. Crawled under to see what caused the problem. The roll pin holding the lever to the shaft linkage snapped. Luckily I had a captive pin with a bale attached so used that after turning it down a bit to fit the hole. Tractor has about 500 hours. Easy fix. Maybe this can help others with similar problem. Bob
/ NX4510 range lever. #2
I had that same exact issue around that same amount of hours. I was pissed that it happened. I think that I installed a new pin and ran a wire thru it.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Allmand Light Tower (A65579)
Allmand Light...
John Deere 785 Manure Spreader (A66408)
John Deere 785...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
