NX4510 range lever.
/ NX4510 range lever. #1
rhunt
aiken sc
kioti nx4510 hst
While moving some logs around yesterday the range selector lever flopped around so now I could not get out of low range. Crawled under to see what caused the problem. The roll pin holding the lever to the shaft linkage snapped. Luckily I had a captive pin with a bale attached so used that after turning it down a bit to fit the hole. Tractor has about 500 hours. Easy fix. Maybe this can help others with similar problem. Bob
/ NX4510 range lever. #2
I had that same exact issue around that same amount of hours. I was pissed that it happened. I think that I installed a new pin and ran a wire thru it.
2015 Harley-Davidson FLHP Motorcycle. (A61569)
2015...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
2023 Chevrolet Express 2500 Cargo Van (A61568)
2023 Chevrolet...
Four R207782 John Deere Wheel Weights (A63116)
Four R207782 John...
UNUSED KUBOTA B2366 PIN ON QUICK ATTACH (A62130)
UNUSED KUBOTA...
