Novice wants a MIG, advise ?
   / Novice wants a MIG, advise ? #21
Do yourself a favor and get a 200 to 250 amp machine, otherwise you will always regret it. Miller 250 or similar. Watch some welding videos, get yourself some scrap metal and start burning wire. You'll never learn unless you do it. MIG is easy, at least to me. I taught myself to stick weld years ago on may dad's old Miller Dialarc 300. After learning to stick weld, MIG was easy. I'm a soso welder. In my world I'm perfect. I can stick it together, it stays and it looks halfway decent.
I am thinking you are right here. In the past, I went cheap on something and regretted it. I do not think it would be difficult to learn MIG, at least for my projects. Not doing anything "serious" - anything that needed 100% proper welds to be safe. My biggest problem welding with Stick is my depth perception and when the rod is full length. The shorter it gets, the better my welds. :) Not just seeing but holding proper distance at the same time. Of course, I DO NOT practice enough either. Typically, I have 1-2 hours to do anything and then need to do something else. So, I dash out to the shop get it done and cleanup. Always wanted a MIG since I have used stick and noted I needed to be much closer to the work piece. The magnifiers in the helmet didn't help that much, it was more keeping the distance as the stick burnt down.
   / Novice wants a MIG, advise ? #23
I use a 180 Lincoln with a gas bottle. This unit does all I need. Will weld tractor repairs and mods. I Built a trailer with it once. It's 220v. I paid about $500. I have since given my 220v AC stick welder away.
I see the new Lincoln 200 for that money now. I did not get the aluminum welding gun with it. IF I were to replace it it would ve another lincoln with the aluminum gun addition. But I may never replace it, I had it for 12-15 years now.
Be sure to show us what you choose.
   / Novice wants a MIG, advise ? #24
90% of what I do is spray transfer so I require at least 250 amps of weld power and of course shielding gas. My preference is ESAB pulsed MIG. Pulsed MIG gives you a TIG quality weld with the speed of a MIG.
   / Novice wants a MIG, advise ? #25
All I've only ever owned and currently own are Lincolns and Hobart's, imo and experience you probably won't regret either brand, I use my Hobart 210mvp which has been problem free for almost 15 yrs it also gives you the option of using either 120/240 volt, rarely hit the duty cycle never had a problem with penetration with it but did take a little fine tuning for thinner wall, especially using flux core. Only thing I wish it didn't have were tap settings for amperage which is unlike the Lincolns I've owned. Imo you get what you pay for.
   / Novice wants a MIG, advise ? #26
Were it not for "My tractor won't start,what's wrong with it?" and "Which welder should I buy?" weeds would grow up around this site.
There is no one size fits all welder. If you expect meaningful advice,you need to lay out ALL your concerns in post #1,not wait until #22 to say "My biggest problem welding with Stick is my depth perception and when the rod is full length. The shorter it gets, the better my welds. :) Not just seeing but holding proper distance at the same time." Before discarding your stick try some 3/32 7024 rods on thin metal. You will find it easier to strike , re-strike and hold an arc than other rods. The filler burns out inside flux allowing you to lightly DRAG rod along in contact with work while maintaining arc without sticking rod. Don't manipulate or weave rod,just move along in a straight line while watching puddle and FEELING for arc length.
Mig isn't a magic solution for your problem, it can conceal a bigger problem unless you learn and apply proper techniques same as stick and TIG. It's easy making pretty beads with GMAW but unless properly done the bead is little more than you can get with an electric caulk gun. Play around with the 7024s while weighing other options,all you have to lose is a few dollars worth of rods but you might gain confidence in yourself.
   / Novice wants a MIG, advise ? #28
When you get your MIG welder you will really need to practice so that you can make good welds. MIG welding makes it easy to produce welds that look good, or even great, but are actually pretty much just sitting on the surface of the parent metal. So when stressed they break off. I have seen this many times. I have been gas welding for 53 years and arc welding for 42 years. When I first got my little Lincoln SP125Plus I was laughing while I was welding because it was so easy and fun. But even though I was good at gas, stick, and TIG welding I had almost no experience wire feed welding so I practiced and took a 1 day class. Since you, the OP, can't take a class I suggest perusing YouTube to get some teaching. Welding Tips and Tricks is a good source. There are plenty others too. And after you have run a few beads on some scrap do everything you can to make them fail. See if you can cause the bead to pull out of the parent metal. See if you can make the bead break. If welded properly the weld bead will be stronger than the parent metal. The parent metal should fail before the weld. The weld bead should not tear out of the parent metal. The pieces welded should fail outside of the heat affected zone. Wirefeed welding is fun. It is generally called MIG welding but actually MIG welding requires gas. Fluxcore, also called Innershield, uses no gas. Dual shield, which uses a fluxcore wire and requires shielding gas, is another type of wirefeed welding. Fluxcore welding is pretty handy when welding in windy conditions but spatters more than MIG. I use fluxcore most often when welding outside and when welding stuff that isn't perfectly clean. Like when I had to build up my backhoe bucket in a few places because it had started to wear through. I know you are going to enjoy your new wirefeed welder.
Eric
   / Novice wants a MIG, advise ? #29
... after you have run a few beads on some scrap do everything you can to make them fail. ... If welded properly the weld bead will be stronger than the parent metal. The parent metal should fail before the weld.
I showed some examples of this in a post over on WeldingSite. I had to bend the welded material back on itself, 180 degrees, then hammer it sideways, before it finally tore at the native steel and not at the weld. Then I turned the scraps around and welded the two clean ends together, and bent that 90 degrees, for a picture to show the penetration. Not quite pro quality work but if the weld is stronger than the native metal, then that's sufficient for my farm repairs.
There are people around that have classes. Some classes customized to what you need. Welding Classes
Of course, there are classes "available". I am looking for something akin to a LOCAL continuing ED class, however. I am NOT trying to become a certified welder. The reference you gave is still 2.5hrs drive on way. So, while *possible*, it is impractical.
I had taken a 5-session continuing ED course 10 years ago. It was Stick only but got hands on. The instructor was an experienced welder but was difficult to get his attention during hands-on time. There were (2) females trying to build a BBQ pit and he spent 95% of the shop time with them. :) Having said that, it was WELL WORTH the money just to get hands-on learn the Very Basics and do some beads. At one time, there were many of these continuing ED classes for various subjects offered mainly at community colleges, high school shops. They seem to have all vanished?
So, when I mentioned "training", I wish I could find one for MIG. Just setup the machine, discuss weld settings, common type issues, a little practice... that's it. I'm sure thru U-tube / other resources I can get myself setup and going. Think I am one of those who just like hands on first.
Massey Ferguson 9250 (A56436)
Massey Ferguson...
TAKEUCHI TB235-2 EXCAVATOR (A52709)
TAKEUCHI TB235-2...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2016 Kia Soul SUV (A56859)
2016 Kia Soul SUV...
JOHNSON OUTBOARD MOTOR (A58374)
JOHNSON OUTBOARD...
