Not to Brag, but...
   / Not to Brag, but... #51
I have found that if I lube the splines on the PTO shaft, as well as the shaft locking component--be it a collet or a pin-locking type--it helps get that part done better. I also keep a 4 foot crowbar handy to adjust the positioning of the mower. That saves on the back-breaking labor...and probably the cuss-words.
   / Not to Brag, but... #53
Hmmmm....I never thought that hitching up a tool to another tool was a race against time.
Taking the time to make sure that everything is connected correctly just makes sense.
Sort of taking a page out of a pilot's handbook. Use a checklist, do it all, do it right, will prevent most problems.
When at 4000ft+ in the air (or when other things are spinning wildly), that is not the time to remember that you did not do something or right.
Congratulations! Do you have it on a dolly? I made one for mine and it's made connecting it much faster and easier. It's easier to move it to its storage location, too.
No dolly for mine. Can you post a picture?
It wasn't a race, it just went really smooth.
Um...ya think?
Do you know the difference between a tractor and a plane? :unsure:
   / Not to Brag, but... #56
I use a drill rod that is about 5 feet long as a lever to move my brush cutter into final position for hookup to the 3pt hitch. Parking on a level spot also helps a lot.
Harbor Freight sells a digging bar that looks like would make a good, long lever.
Good idea, I have a couple 5'-6' rock bars.
   / Not to Brag, but... #58
Previous post with pictures here:
   / Not to Brag, but... #59
I rest the front end of the cutter on 2' 6"X6" blocks, one on each side, when I store the cutter. I can pivot it around to get the arms attached by grabbing the tailwheel to move it around. It slides easily on the wood. Then I use a small ratchet strap to hold up the PTO shaft level with the PTO stub. Run it under the shaft and hook both ends to where the top link attaches to the cutter. That way I can use all my force to slide it forward instead of having to hold it up.
   / Not to Brag, but... #60
Got my bush mower hooked up in record time. Like 10 minutes total.
That's a record for me.
If you all haven't heard of these, they are game-changers for me. First, I use the iMatch quick connect/disconnect system LVB25976: iMatch™ Quick Hitch Coupler Attachment, Category 1 | LVB25976 matched up the PTO Link Easy PTO quick connect for tractor attachments. You can probably find the iMatch cheaper online than you can get it at John Deere. I can hook up in less than a minute. The PTO Link is the shizzle. They make standard and heavy-duty. I pull an MX6 and use the Heavy-Duty on our 5075E
Miller Bobcat 250 Diesel Welder (A54865)
Miller Bobcat 250...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2022 RK25 PERMORMANCE SERIES TRACTOR (A54756)
2022 RK25...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2015 Honda Accord Sedan (A55758)
2015 Honda Accord...
