Not charging
/ Not charging #1
Ramgarza155
Mahindra 3525
I have a Mahindra 3525 that is not charging new battery I installed the battery it would turn on had it running for hour then the next day it was dead I had to put jumper cables for it can start when the battery is at 12 volts the volt slowly go down when running then at 5 volts that’s when it dies I put the voltmeter while it’s running the voltage doesn’t go up I bring the rpm to 1500 still doesn’t go up I put a new alternator too but still doing the same thing check the fuses there good has a new ground wire too I checked the voltage at the back of the alternator it’s the same voltage as the battery the red light on the instrument cluster only turns on when I’m jumping the battery what can be the problem? And also the ksb relay might be bad bc I did a ohm test on the relay get no reading idk if that matters with the alternator it runs with the relay disconnect
/ Not charging #2
I don't know Mahindra. Is the voltage regulator part of the alternator or a separate unit?
/ Not charging #3
One thing I always do is I install a master disconnect on the NEGATIVE side of all my starting batteries and I break them out of circuit when not being used. That will eliminate any discharge situation and it sounds to me like you have a wire issue somewhere.
/ Not charging #4
No power at alternator means it's not charging. Most auto shops can verify on a bench, but pretty sure the new one is bad.
/ Not charging #6
Take one or both alternators to an alternator repair shop and have them checked. This would likely be a shop that can work on them not your local auto parts store.
