normal operating engine rpm?
/ normal operating engine rpm? #1
Gus3120
Hancock md
2005 john deere 3120
Im new to cuts, I have been doing some work around the property that requires moving dirt and some mild digging such as cutting water breakers in my driveway. My question is during normal operation what is the best rpm to set the the engine at? I致e been running my jd3120 at around 2300 and it seems happy since it痴 max torque is right around that. Is this too high or low?
/ normal operating engine rpm? #2
Seems pretty good to me. Running it at low rpm all the time can lead to soot build up and not enough heat build up for DPF regeneration.
/ normal operating engine rpm? #3
I run between 2000 and 2500 rpm all the time.
I only idle for 1 minute at cold start and 1 minute prior to shut down.
/ normal operating engine rpm? #4
2100 rpm is the 'sweet spot' on my 4105 for just about anything I'm doing unless I'm using the PTO, of course. Anything more and I'm simply sucking more fuel for the same amount of work.
Thx for the reply痴, I know that my tractor makes peak hp around 2600 rpm but running it that high seems excessive and would be burning more fuel. Last Saturday I worked the machine for 5 hrs and burnt roughly 2.5 gal of fuel which I thought was pretty good.
/ normal operating engine rpm? #6
2000 rpm if your not in hurry,just don't lug the motor down.
/ normal operating engine rpm? #7
Task dependent?
I was digging post holes with my PHD this past weekend. 800-900 worked best, easier to control the auger.
/ normal operating engine rpm? #8
I've been playing around with stall-guard and auto-throttle. Under auto-throttle it seems like 2K rpm is where the tractor goes to when you touch the go pedal, and it goes up from there. Admittedly I did some napkin math and the tractor's weight, fully dressed up, is about a ton more than bare weight. 6100lbs operating weight and 35HP make for a high rev situation, I guess.
I usually worked the L3301 at PTO RPM, even if I was pulling a box blade or working the FEL. Kept the pump noise down somewhat and gave better control "feel".
/ normal operating engine rpm? #9
Like widefat - task dependent. My "hardest" task - plowing snow/clearing driveway ditches. There I will run up to 2100 rpm. I think that's around the same rpm to get 540 at the pto when I run the chipper.
Summer driveway surface maintenance - around 1800 rpm. I go slow - easier to control the job and its outcome.
I can make mistakes fast enough even at slower speeds/rpm's. No need to speed this up.
/ normal operating engine rpm? #10
Depends on what I'm doing. If I'm running a pto tool, then either 2000 on 540E, or 2500 on straight 540. If I'm doing FEL work, then I set the idle up to 1500 (increases bucket curl/dump speed), and the linked foot pedals will increase engine rpm as I call for more ground speed.
/ normal operating engine rpm? #11
I don't think you could generalize an answer that fits all tractors under all conditions. My advice: Whatever works, and the slower the better as long as you don't run it so slow it stalls it.
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
8' DISC HARROW (A60430)
8' DISC HARROW...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2009 Wilson Hopper Bottom Trailer (A66285)
2009 Wilson Hopper...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
