noooooooooooooooo!!!!
/ noooooooooooooooo!!!! #21
Since you seem to have received plenty of good advice already, I thought I'd share one of the many stick experiences I've had. Whlile going to college I worked for a home builder. I was clearing an overgrown parcel of land to be used for farming with a Caterpiller 955 track loader. There were a lot of tall but small in diameter, 2-3 inch maple trees. Although I was very careful and wary of the dangers these trees pose, I was backing up, and all of the sudden a maple came through an opening in the back of the tractor. It continued through the seat between the back and the bottom narrowly missing me. Talk about almost gettiing a stick up my a....
I try to be very careful with my Kubota.
/ noooooooooooooooo!!!! #22
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Seems like a water pump runs on a sealed bearing that turns an impeller that's in your cooling system. How can running it w/o water damage it? It's not like the antifreeze provides lubrication. I'm sure I'll be corrected if I'm wrong. /forums/images/graemlins/crazy.gif )</font>
The engine gets hot and in a hurry without water going thru the block. Without water, BLEEEEEEEEEEEEEEEEWY! )</font>
I understand all that, but it won't go blewy in 30 seconds. I was curious as to how the water pump would be damaged, forgot about the seal in the pump losing lubrication.
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
1997 Ford F-350 4x4 Utility Truck (Diesel), VIN # 1FDKF38F6VEA38713 (A65563)
1997 Ford F-350...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
