noooooooooooooooo!!!!
/ noooooooooooooooo!!!! #21
Since you seem to have received plenty of good advice already, I thought I'd share one of the many stick experiences I've had. Whlile going to college I worked for a home builder. I was clearing an overgrown parcel of land to be used for farming with a Caterpiller 955 track loader. There were a lot of tall but small in diameter, 2-3 inch maple trees. Although I was very careful and wary of the dangers these trees pose, I was backing up, and all of the sudden a maple came through an opening in the back of the tractor. It continued through the seat between the back and the bottom narrowly missing me. Talk about almost gettiing a stick up my a....
I try to be very careful with my Kubota.
/ noooooooooooooooo!!!! #22
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Seems like a water pump runs on a sealed bearing that turns an impeller that's in your cooling system. How can running it w/o water damage it? It's not like the antifreeze provides lubrication. I'm sure I'll be corrected if I'm wrong. /forums/images/graemlins/crazy.gif )</font>
The engine gets hot and in a hurry without water going thru the block. Without water, BLEEEEEEEEEEEEEEEEWY! )</font>
I understand all that, but it won't go blewy in 30 seconds. I was curious as to how the water pump would be damaged, forgot about the seal in the pump losing lubrication.
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
Husqvarna K750 Chainsaw (A65579)
Husqvarna K750...
2013 Ford F650 Fuel & Lube (A62613)
2013 Ford F650...
Manure Spreader (A65640)
Manure Spreader...
2015 QUALITECH FUEL POD TRAILER (A65643)
2015 QUALITECH...
2021 PC210L Komatsu Hydraulic Excavator (A64553)
2021 PC210L...
