3-Point Hitch noob hydralic question
/ noob hydralic question #1
Cutterhead
Washington
Kubota L3400
Ok, a newbie question about the 3pt hydraulics: I have an L3400; does the hydraulic power only work "up" and the "down" is gravity?
/ noob hydralic question #2
It is power up and then gravity down, if you have a moldboard plow the amount of suck you have(allow) will also pull the moldboard further in the ground as well.:cool:
/ noob hydralic question #3
That is correct. If you push the lever forward on mine with nothing on the hitch, the arms just slowly sink down. Push it forward with the box blade connected and you better have your toes out of the way.
/ noob hydralic question #4
The good thing is gravity never breaks :thumbsup:
Or ... well ... if it does, we're all in deep trouble. GRAB HOLD OF SOMETHING!!! (Oops, no, that wouldn't help)
thanks all. And no extra charge for gravity either.
/ noob hydralic question #6
Don't stop there.
google "single acting hydraulic cylinder" (A) and contrast with "double acting hydraulic cylinder" (B).
Wrooster
Figure 4-11. (A) Single- and (B) double-acting hydraulic cylinders
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
2012 Ford F350 (A62679)
2012 Ford F350...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Hyster 50 5,000lb Propane Forklift (A64553)
Hyster 50 5,000lb...
Water Pump with Engine (A65640)
Water Pump with...
