Nonstick for dump trailer
/ Nonstick for dump trailer #21
I'm not exactly sure of the measurements of my dump bed, but you can get an idea of it's size from the attached picture. I went up about halfway on the sides and worked my way back to where my ladder was. I have about a quarter gallon left over and I put it on pretty thick. I didn't know how much I would need, or I would have gone all the way up the sides. Of course, it doesn't really stick on the sides, so I guess it doesn't really matter. My problems started in the corners and then worked it's way out to the middle.
For prep, I hosed and scrubed the bed clean. No soap or chemicals, though I'm not sure if that's an issue or not. I didn't use any, so I don't know if you can or shouldn't. I let it dry out, then just painted it on over the rust and the metal.
It was a simple process, but the paint is very sticky and does a spiderweb type thing. It will get all over you and be very, very dificult to get off.
I just dumped some out onto my bed and used a half sized paint roller to spread it out. Then I through the roller away when I was done.
Eddie
/ Nonstick for dump trailer #22
DUSTMAKER said:
I bought a new dump trailer recently and after dumping about a dozen times with four different materials it seams a lot of them stick in the trailer. Bark and dirt seam to stick the most. This trailer only tilts to about 40 degrees, is that about normal for a small dump trailer 7x10 with single acting cylinders, or should I have researched this more? Is there a material I could spray or lay in the bottom that would allow the material to slide better? Any help would be appreciated .
Thanks
I have heard that bedlinner spray in works (like LineX, Rinno) I was told they need to leave the rubber additive out, for a smoother finish
/ Nonstick for dump trailer #23
I'm interested in knowing how this product worked for every one on the mower deck. I have a 60" commercial mower and mow about 5 acres around my house. I have to keep the deck clean or I get a stripe on every pass, so I clean it often. If this works well I'll do my mower deck and skid steer bucket.
/ Nonstick for dump trailer #24
If you know you are going to be trying to dump really sticky stuff, you can line your dump bed with news paper held on with masking tape. You can use butcher paper or whatever is cheap. Visqueen and such plastic can be a hassle as it will be in yoiur dumped load. Note when you dump your impromptu liner will most likely end up partially buried so biodegradable or otherwise non interfering stuff like paper or cardboard are often a good choice.
Even some straw or grass trimmings can help,especially in those "problem areas" that never seem to dump cleanly.
Pat
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A61572)
2015 A and A...
INSPECTION (A65563)
INSPECTION (A65563)
213083 (A64276)
213083 (A64276)
2017 Volvo VNL T/A Sleeper Truck Tractor (A61573)
2017 Volvo VNL T/A...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
