Non-stick paint
/ Non-stick paint #11
I've used Slip-Plate on my mower decks to prevent sticking and it works pretty well. The "trick" is to read the directions. After applying a thick coat or two, and after it thoroughly dries, you need to burnish the coating which leaves it smooth and very slick. One coating will last the entire season and prevents the acids from the grass eating into the deck. To burnish I use a fine to medium wire cup brush on a right angle grinder going over the surface like polishing a car.
Now for my 2750D blower, it get repainted (edit: with Chevy Orange engine paint) inside each season, especially inside the fan and on any exposed metal. Before a wet slow, I spray silicone liberally over everything, sometimes use PAM, the worst performer for me is WD-40. Also spray the shovels with silcone to prevent sticking.
/ Non-stick paint #13
u sti have a bucket truck?I JUST POSTED PROBLEM ON TRACTOR FORUM WILL YOU LOOK AT IT?GOURD HEAD
/ Non-stick paint #14
Butchers paste wax and a little elbow grease.
mark
/ Non-stick paint #15
UHMW plastic, particularly the black stuff with graphite in it is REAL slippery, and tough!
What I'd do is first fix/support the universal so that it runs true and doesn't slam into the sides. Then I'd wire wheel or even better blast the interior and coat with a couple coats of POR 15. Once that was done, I'd line with the UHMW. A bit of work yes, but it would last a LONG time.
/ Non-stick paint #16
Its less costly to use slick sheet leftovers from Horn Plastics
and the flat head bolts from Gemplers used to anchor thier
plastic panel systems.
/ Non-stick paint #17
Leon, do you have links for those?
/ Non-stick paint #18
If you're addressing me, yup, I still have a bucket truck. Can you give me a little better info about where to look at the post you're talking about?
/ Non-stick paint #19
Paint it with an epoxy paint. Epoxy is durable and it is slippery compared to other paints.
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
YANMAR XIO35-6A EXCAVATOR (A59823)
YANMAR XIO35-6A...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
2007 Ford Taurus Sedan (A59231)
2007 Ford Taurus...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
