joea99
Platinum Member
Lately have a need to change buckets on Kubota backhoe, swapping between a toothed and smooth bucket and a "root ripper" claw from Bxpanded. Which BTW makes root ripping almost fun. But I may be repeating myself. Attachment is via a conventional (?) nut and bolt though the pin hole.
While that is OK, especially since I am way to cheap to spring for any of the quick change setups, I'm looking for a way to replace the nut and bolt with something secure but quick. It's a bit tedious as there is not enough room to get a gear-wrench or any kind of ratchet on there, only a open end or (some) box ends will fit.
So, looking for some sort of pin and clip that would be secure enough to dig with and not come loose.
