Non Powered Kerosene Heaters
   / Non Powered Kerosene Heaters #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I have been getting one of these Early 80s style kerosene going. I thought I needed a new wick, but the one I bought almost twenty years ago now, is no longer than the one that came out. Seems they don't have a lot of wick length that can be utilized. Like 1/4" !
I would like to know about using Diesel Fuel. Internet tells me I can add one teaspoon rubbing alcohol to a gallon of Diesel with good results. If Diesel doesn't evaporate as well as Kerosene, how is one teaspoon alcohol going to make a difference?
Also, these heaters are not very good at making lots of heat, yet they have to be in a ventilated area. Too ventilated and you won't be able to heat the space with these 10,000 BTU heaters.
I wanted to work in my unheated barn, and not have the heater heat the space, but provide local radiant heat. Seems like it won't be up to the task.
   / Non Powered Kerosene Heaters #2
I guess its possible and a little cheaper probably put out a tad more heat but also a lot more stink.
I should get the Link of the Canuck out East. Says less stink with Diesel/Alcohol
I always think of a very early youtube video I saw, where someone pried open a car battery and it was jam packed with AA Cells! So, I like to verify information before just accepting anything.
Found this new Video. Interesting as for the safety standpoint. Now, he says 3 Oz 90% alcohol for a gallon. that is starting to make more sense.
   / Non Powered Kerosene Heaters #5
Think diesel has more paraffin molecules in it, will gum up the wick (burning end) way faster than kerosene.
   / Non Powered Kerosene Heaters #6
Why don't you just buy kerosene?
The price has been prohibitive for decades. Maybe four times the cost of Diesel. Maybe even more.
Thanks I7. I read of of Gumming up the wick but no explanation. I wonder if alcohol addresses that issue. Judging by the tiny amount of wick available for consumption, I'm guessing the wick really doesn't burn at all.
   / Non Powered Kerosene Heaters #8
Throw it away and buy a forced air torpedo. Get a propane if you want clean and diesel if you want cheap. Well used to be cheap it’s up close to $3 a gallon here.
   / Non Powered Kerosene Heaters #9
You could look at a deisel cab heater, i believe the can do up to 25000 btu
Of course I have one of those Cab heaters. Why wouldn't I? lol I have never played with it. I kind of wanted radiant heat. I wanted to clean up the barn a bit and have a source of radiant heat. Just like I have a wood stove fire going in my garage with the door open. It just takes off the chill.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Mitsubishi FGC25 (A47477)
Mitsubishi FGC25...
8ft Fork Extensions (A55787)
8ft Fork...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A55787)
2017 Bomag BW90...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
