Noisy Tach Cable?
/ Noisy Tach Cable? #1
wsp617
Wisconsin
JD 1070
This the first year I've owned my JD 1070. I haven't run it in awhile and I got it started the other day when it was COLD (6 degrees). There is a whining or squealing that sounds like it's coming from the dash area and the tach needle is jumping. I'm guessing it's the tach cable. Is this a common issue? Is it a cold weather issue as it never did it all year. Is it something that can be lubed?
Thanks
/ Noisy Tach Cable? #2
Yes it can be lubed take the end off at motor put some graphite in like you would use on a lock.
Usually the spiral will pull it up the tube and lube it self.
Their might be as lube JD recommends call a dealer and ask.
tom
/ Noisy Tach Cable?
OK, Thanks.
I'll try the JD dealer tomorrow.
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
