No thermostat?
/ No thermostat? #61
woodchuckie said:
Was the water sack for adding water to the radiator or what. I've never heard of that. Why was it hanging from the hood instead of being in the trunk or something.
Like the Lister Bag which was in use when I hung up my combat boots circa 40 years ago, and may still be in use as far as I know. A good, low tech way of keeping drinking water reasonably cool.
/ No thermostat? #62
I saw a discovery channel show last night on the nuclear facility that produced our plutonium for the 40's thru the 70's.. etc.. Something like 9-12 reactors at one time.
in any case.. their water cooling system the pumped right out of the river.. the water passed thru the reactor under pressure.. took about a second for the water to pass thru. Something like 27,000 GMP was the flow rate for their reactor cooling system.
That should put the water cooling / speed issue into a little bit of perspective.. etc.
Worst aprt was the water got dumped right back into the river afterwards! Big cleanup issue now....
Soundguy
/ No thermostat? #63
The water sacks were often seen on cars in the great American southwest (especialy in the desert.) The sacks were of a slightly porous nature. The air hitting the sacks caused evaporation which cooled the contents. It had little or nothing to do with water for your radiator as it was intended to make cool drinking water. It worked fine out there where the relative humidity was low.
Pat
/ No thermostat? #64
Speaking of evap and realitive humidity. Long time ago...Anyone else ever use one of those wet bulb / dry bulp 'swinging' thermometers in order to figure RH?
Soundguy
/ No thermostat? #65
Soundguy
You refer to a sling psychrometer which is composed of two thermometers, one dry bulb and the other a wet bulb. The one thermometer (usually mercury or alcohol in a cap tube) had its reservoir bulb in a little cloth sack with its other end in a small container of water.
You sling the thing around in a circle at high speed and the evaporative cooling reduces the reading on the wet thermometer. The difference in temperatures between the wet and dry thermometers indicated the relative humidity. You just looked up the temps in a chart to get the RH.
These are still used although there are electronic sensors available to do the job now.
Pat
/ No thermostat? #66
When I was in Huntsville, AL in the early 70's, I recall the local paper reported that the EPA (or some government bureaucracy) tried to shut down the TVA nuclear generating plant at Muscle Shoals. The plant drew its cooling water from a reservoir fed by the Tenn. river and returned the water to the reservoir which then emptied back into the Tenn. River.
One of the regulatory/environmental constraints on the plant was that the temperature differential between the water entering the reservoir and that exiting back into the river couldn't exceed some relatively small value. One day, the EPA monitors discovered the temperature differential was out of limits and called on the plant to shut down until the temperatures returned to within specification.
Turns out the plant had been offline for maintenace, refueling, or some such, and hadn't been running any cooling water through the plant for several days. The sun, that nuclear furnace in the sky, was heating the reservoir surface more than the EPA would allow. Don't recall whether or not they tried to get a court order to have the sun reduce its output temporarily.
Possibly an urban legend, but my experiences with government bureaucrats does not lead me to doubt the report.
/ No thermostat? #67
Tom, San Onofre nuclear power station just north of San Diego uses open loop cooling with sea water. Aqua culture experiments like growing species who need warmer water and such were pretty successful (if you ignore the baby fish with 3-4 eyes and an extra tail.) Just kidding about the genetic mutations.
The cooling water, whether from the ocean or a river does not go through the reactor to cool it! A recirculating transfer medium is used to carry the heat from the reactor to heat exchangers where it is transfered to the cooling water. The water doesn't "see" a lot of radiation. The faster they flow the water through the heat exchangers the better they work (within reason, yoiu don't want hypersonic turbulence) and the lower the temperature of the effluent stream.
Pat
/ No thermostat? #68
When using raw water as a coolant the high flow rates may help keep the exchange surfaces scoured clean and prevent fouling or bacterial/animal growth. It may also keep all dissolved minerals in solution so they do not precipitate out.:D :D
have not water coolers in the guise of "Olla's" been in use from days long before out time.
There are also many an evaporative type cooling tower in use for cooling water. All those white plumes from the tops of tall buildings may be such a unit in operation.
/ No thermostat? #69
Good benefits on keeping passeges clean but the algae huggers don't care if your equipment fails they just want a small delta T in the discharge water.
There are evaporative coolers that work well for residential use and have no "filter media" like the excelsior, fiber glass mats etc. They just spray a mist over the top of a chimney. The cooling from some of that mist evaporating makes the air heavier and it falls down the chimney which sucks in more ambient air and you have a continuous gravity flow of cool air down the chimney (tower?) These systems require rather large ducts. I have never seen one with muich of a distribution system, typically just a large hole in a central (like a great room) wall that looks like a fireplace but emits a fair draft of cool air.
The advantages are obvious. NO electricity needed which makes them fine for a solar powered residence. They only work really well where there is low relative humidity (desert of near desert like conditions.
Hows that for marginally related triviata?
Pat
/ No thermostat? #70
patrick_g said:
Tom, San Onofre nuclear power station just north of San Diego uses open loop cooling with sea water. Aqua culture experiments like growing species who need warmer water and such were pretty successful (if you ignore the baby fish with 3-4 eyes and an extra tail.) Just kidding about the genetic mutations. ...
I've sometimes wondered about the dilemma that would be faced by environmental organizations under circumstances where long term operations have changed the downstream ecology to favor warm water species. If one of the existing, favored species happened to be on an endangered species list, would the organization lobby to prevent shutting the plant down?
And you're right that the cooling water doesn't come in direct contact with the reactor core. Radiation in the effluent significantly exceeding background levels would indicate a very serious problem in the cooling system.
/ No thermostat? #71
Tom, Of course some environmental regulations are a very good thing as are some environmentalists but the extremists and some of the whacko things that happoen are a source of amusement, consternation, and indignant backlash.
When I was at SUBASE San Diego the base civil engineer was not permitted to cut down the Eucalyptus trees (not native to California but a failed experiment in growing wood for railroad ties but they wouldn't hold the spikes.) They weren't allowed to cut the trees because the night herons were roosting in them (and messing up all the nearby parked cars.) The Herons favored the trees solely because they were in direct line of sight of the bait barge where they liked to go steal bait fish. Not exactly a case of trying to preserve the original natural order of things.
The civil engineer started having the trees radically pruned a few weeks ahead of the birds nesting season. The birds just moved "next door" and carried on business as usual. Removing the non-native trees would have been a move toward restoring the natural balance.
Meanwhile the park rangers at the Cabrillo National Monument were seeking out diseased ice plant to spread the disease to kill out the ice plant growing on their property. They were afraid that there would be a backlash from the ENVIRONMENTALISTS if they dug it up or sprayed it to kill it so they spread a plant disease on the sly to try to get it to die from natural causes so they could eliminate this imported exotic that competed with native species.
Pat
/ No thermostat? #72
Here in my South we once introduced the non-native beaver to stop any erosion missed by the non-native kudzoo which was introduced because the edge of our cultivated fields consisted of sand, sand and more sand. We now have kudzoo except where it's too wet because of the federaly protected wetlands caused by the beaver. Now what was that dangerous insect I heard about that eats fireants.
/ No thermostat? #73
skipmarcy said:
Monte & Catman are both correct. Alot of uneducated people will remove a thermostat trying to fix a overheating problem and just cause themselves more grief. To clarify why an engine would actually overheat with a thermostat removed - at higher operating RPMs the water pump is circulating the coolant too fast for proper heat transfer, first the heat from the engine to the coolant, then the heat from the coolant to the radiator cores, it's not staying there long enough for the heat transfer to occur. Now if you have a radiator that's half clogged it might cut the flow enough to fool you into believing you've "fixed" the problem by removing the thermostat, but all you've done is mask the real rpoblem and it's going to bite you in the...
I've never heard of overheating because the thermostat was removed... and i doubt if removing the thermostat makes that much difference in flow restriction, as the coolant liquid finds its way through narrow holes and galleys in the cylinder heads and around the walls.
My brother once bought a Nissan Patrol 2.8 turbo diesel jeep. The engine didnt came to operating temperature on chilly days so we assumed the thermostat was stuck in open position.
When the guy he bought it from, sent a thermostat by mail, we opened the thermostat housing and found.... just an empty housing. when we put in the thermostat, it overheated every small trip.
The cause of this, is loss of compression by leaks, mostly through the valves, or by the piston rings.
About flow, i had a cooling problem on the Zetor 5245. It overheated quickly even though the previous owner replaced the original fan for a BMW automobile fan, to get some extra wind draft.
After asking around, i found that some models came with a fine mazed radiator: it had the double amount of pipes, with half the diameter.
Both water flow THROUGH the pipes, and air flow AROUND the pipes were too much restricted. I replaced it with a coarse mazed radiator of a wrecker, a 5718 of early 70's. I also polished the valves and valve seats, which were pitted because of earlier overheating.
I also turned open the fuel pump a turn or 2, and with the extra power i have a much smoother tractor that hasnt gone over 105ーC again in the hottest summer days.
About the need of a thermostat, as mentioned by others, the engine has to get to a reasonable exhaust gas temperature to prevent carbon build up, and to vaporise condensates of fuel and water in the oil.
/ No thermostat? #74
According to the show i saw.. there were no heat exchangers.. and the reactors that they were using to cook up plutonium was putting out pretty heavilly contaminated water. The show showed areas downstream of the reactors.. and everything looke dlike a superfund clean up site.. YUCK!
Soundguy
Pat
/ No thermostat? #76
Was on the discovery channel.. they did a program on the uranium to plutonium reactor processing for the first nukes we built .. then on to cover the city that grey up arounf the area to support it.. etc..
Soundguy
/ No thermostat? #77
Egon said:
What show was That?
I saw the same show a few days ago, it was either on the History channel or Discovery channel. Can't remember the name of it but it was all about the nuclear experimentation & buildup in th USA. This reactor site was in Washington state. Usually these channels will repeat programs like this, might be able to catch it sometime again soon.
/ No thermostat? #78
I saw the show too, Discovery or History channel. They gave a general description of pumping the river water directly through the long irradiating tube/core sets, and mentioned an incredibly short time (a couple seconds) it took for the water to pass completely through it, front to back. This was to maintain the water temperature within a couple degrees from entry to exit, which was critical. They did mention that there was a radioactive waste issue but that this was war time and would be dealt with "later." There was no mention of filtering or any kind of water treatment but those kind of shows never do get into that kind of detail.
Bill
/ No thermostat? #79
Yep.. that's the progrm i saw. And then they took that boat ride and showed the closed down reactors.. and then talked about the contaminants trapped in t he radioactive sludge at the bottom o f the channel.. etc..
Was a neat show.
Followed by the nuke silo's that had missle protection.. etc..
Soundguy
/ No thermostat? #80
Here in Oklahoma, among other species, we have large red ants. These red ants can bite like the devil if you are foolish enough to stand or sit on one of their mounds but are nothing compared to fire ants (small dark colored ants.) Our red ants and fire ants do not collocate. The native red ants will fiercely defend their territory by killing out the fire ants.
I used to give the red ants grief of various sorts including driving over or kicking their hills and such. After reading about the red ants killing and preventing fire ants from taking an area the red ants became my new best friends.
I don't know what else is a natural enemy of the fire ant but at least we have native species who are a deterrent to the invading fire ants. Too bad we don't have more of the red ants.
I guess we are lucky to have the red ants. Luckily the Government hasn't introduced scorpions or such to thwart the fire ants (so far.)
Pat
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
Takeuchi TB225 (A62177)
Takeuchi TB225...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
John Deere 920 (A64126)
John Deere 920...
