No start
/ No start #1
Tech1974
Mercersburg pa
International 300 utility
I'm working on a 300 utility the wire shorted out between the ign and starter silanoid I repaired wire but tractor won't start its getting fuel and a weak spark any ideas thanks
/ No start #2
Solenoid might be bad. If the wire shorted and kept the solenoid engaged it could have damaged it. On the same token, the solenoid might have stuck and drew current long enough to heat the ignition wire enough to fail.
Usually aren't too expensive.
/ No start
I had the starter rebuilt and New silanoid
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
King Kutter 7' 3Pt Mower (A66408)
King Kutter 7' 3Pt...
2009 FORD F-450 SUPER DUTY (A65643)
2009 FORD F-450...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
