No spark
/ No spark #1
JohnMC
MI
JD 4210
I have a 85 vintage JD 316 with Onan B43E engine. No spark at the coil/plugs. I have 12v at the coil and test light blinks slightly on negative side of coil while cranking. Points look good & will spark/arc slightly when I insert a feeler gauge w/ign on. Not sure how to check condenser. Check fuses & connectors at ign switch & downstream in the wire harness. I also just noticed that the points don't move when cranking engine. There is a small pin under the points plate that is supposed to cycle the points open/closed. Does anyone know what the length of that pin should be? Terminals are clean. Anybody have any more ideas before I buy a new coil? Thanks.....
/ No spark #2
I've seen those pins get stuck after engine sitting long time.
Use q-tip to get very small amount WD or some other penetrant oil around pin and work it loose.
/ No spark
Finally fixed it. The points weren't moving because the baseplate that the points attach to wasn't positioned correctly causing a side load on the pin & keeping it in the up position. Once I centered the baseplate the plunger moved freely. After that I diagnosed a bad coil. New coil & all is well.
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
Harlo HP6500 (A60462)
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
