No reverse
/ No reverse #1
Steve Phelon
American Fork
Bobcat Toolcat 5600
Lost reverse. Goes forward just fine. No codes have come up. I am sure it is not a hyrdo issue, most likely electrical. Any ideas?
/ No reverse #2
What model? I know there has been some issues when you switch too quickly from forward to reverse. Maybe Doxie has more information if you can post your model.
/ No reverse #3
if it was Hydro it should loose drive both directions.
no code would mean controller is not seeing an input - fault in directional lever or wire circuit to the controller.
Remotely possible that one hydro pump has a directional/check stuck open so that motor does not turn and with axle matching flow to the other motor is shut off. To test for this refer to the operation manual and turn "Axle Matching" OFF, if check valve is stuck open it will drive on one axle.
WESTFIELD WR641 - 6" X 41' GRAIN AUGER (A64278)
WESTFIELD WR641 -...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
1NOP 2002 CLUB CAR ELECTRIC GOLF CART (A65055)
1NOP 2002 CLUB CAR...
2011 Ford Crown Victoria Sedan (A64557)
2011 Ford Crown...
2124 (A65055)
2124 (A65055)
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
