No PTO
/ No PTO #1
stykemainb
Davisboro,Georgia
JD X500, JD M 40T Tricycle
Ok I installed a new PTO on my X500 ran good for a while ofter I shut it off it would not come back on the light on the switch came on but no engagement replaced the switch still nothing any ideas anyone?
/ No PTO #2
Do you have a volt meter? If yes check to see if you are getting voltage to the clutch. If yes then suspect bad connection in the clutch or possibly the connector.
/ No PTO
If the connection is bad I should be able to put in a different connector right
/ No PTO
Can I put power directly to the clutch from battery to see if the clutch worls
/ No PTO #7
If you unplug the connector and then run wires from the battery straight to clutch you should hear it engage. Black wire on the reactor connector is ground. I do NOT know what colors the wires are on the clutch side though.
/ No PTO #8
Is there a safety switch in or on the seat?
2007 Top Brand Deck Over Trailer, 18'+3' Dovetail (A62679)
2007 Top Brand...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
Lot of (4) Square Tube Gates (A66408)
Lot of (4) Square...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
