No hydralic pressure
   / No hydralic pressure #1
kiotirookie
kioti DK35
Tractor is Kioti DK35.
Just drained and refilled trans/hydro fluid and now have no hydraulic pressuer. Is there an air bleeder somehere?
   / No hydralic pressure #3
You probably have lost the prime. After starting engine, you could add air to the hyd tank filler opening with a blow gun and a rag around the nozzle.
If your system is open center hyd system, you have a path to tank with all valves in neutral.
Thank's J.J.
I do believe you mignt have the solution. I shall try this proceedure and hope for the best.
Regards. Peter (kiotirookie)
Hello Egon.
Yes, the filter was changed along the way. Just got an idea from JJ about forcing prime using air pressure. Thanx for responding.
Regards, Peter (kiotirookie)
   / No hydralic pressure #8
If you use air to prime your pump, just go easy on the air. The trans case is vented and runs with no pressure.
To one and all who offered advice.
It took a while to get back to the tractor problem. Familly issues. Anyway, it was indeed a pump priming problem. The air pressure fixed it virtually immediately.
Thanks to everyone and have a good whatever.
Cheers Peter (kiotirookie)
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
2010 FORD F-150 (A53843)
2010 FORD F-150...
