No high range
/ No high range
Exactly I'm not able to hold it it still jumps out and grind.
/ No high range #32
Sounding more serious all the time. If it wants to jump out with you holding it I would think you have worn gears or bad bearings. Could you see those gears when you had the cover off? Any gear teeth rounded off on edges?
/ No high range
I did notice 1 gear ruonded at the edges I was kind of thinking that it was suppose to be that way. i don't know for sure what that gear goes to.
/ No high range #34
All those sliding gears or the ones they mesh with are straight spur gears and should not be rounded on edges. This may not be an ideal picture and not one of the gears you are looking at but this is what your gear teeth should look like. Yanmar Tractor Parts: DROP BOX GEAR _
/ No high range
Ok so now for the big question!! Is this a major repair or something that can be easily replaced with out having to split the case? I'm not really intimidated but would like an idea of what's involved.
/ No high range #36
I believe you need a repair manual before proceeding. I know I would pull any covers that would allow inspection hoping to correctly diagnose what is causing the jumping out of gear. Maybe you have already done that. Just looking at the parts drawings would indicate a lot of separation to change gears in the transmission. Take this as "my opinion" and not fact. I haven't been in one of these and do not have a manual that covers it.
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Trimble Guidance System (A60462)
Trimble Guidance...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
24in excavator tooth bucket (A61307)
24in excavator...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
