Oil & Fuel No fuel from Injector Rail
   / No fuel from Injector Rail #11
With it being under 3 years old isn't it covered under warranty?
I bought the tractor in August of 2005, All of the warranty information that came with the purchase says two years. I think the warranty went to four years in 2006.:mad: :mad: :mad:
Well, I took the sucker apart. Its not that complicated. I found out that the problem was one of the thingys that turn the fuel injector assembly inside of the fuel rail.
I am not sure that I am calling these parts bytheir proper names, but anywho. I will post somepics as soon as I figure out how.
I turns out that he gear teeth were missing on one side of the piece and the broken off bits were clogging the gears of the other injectors. I ended up rotating the broken piece 180 degreesand putting it back in.
I got her back together and after cranking for about 45 seconds, she started sputtering. Then she fired up. I may need to make a few adjustments because I am getting full rpm's but not full power.
   / No fuel from Injector Rail #14
I can tell you that if you did have to buy a new injection pump, those gears will be updated with better gears. Also, I would definately try and get Kioti to cover it even though it may not be covered just because of the low hours on the machine. Just my $.02 :)
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
Enmark Z Spray (A53316)
Enmark Z Spray...
KOMATSU D65EX-18 CRAWLER DOZER (A60429)
KOMATSU D65EX-18...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
26120 (A56859)
26120 (A56859)
