No electric 12v power to the cab
   / No electric 12v power to the cab #31
Sorry for repeating myself but make sure the cab is grounded. Should have a ground strap from engine to cab.
Ok I’ll chk
   / No electric 12v power to the cab #33
Here's another PDF file I found in the which I believe what Harleycb had mentioned in his post. Bad picture but its does show some large fuses in the parts listing.
  • Illustration_04092021.pdf
   / No electric 12v power to the cab #34
Have you checked out the ignition switch? Voltage to the switch? Voltage coming out of the switch?
   / No electric 12v power to the cab #35
Your issue sounds just like what happened to me when I had to work on the starter. On the positive side of the battery cable you have two wires coming off. The thick one goes to the starter, the other smaller one should run underneath the radiator. Follow that back and there is likely a bad connector within 10 inches of the battery. It's a plastic blade connector that splits that small wire into two that feed the main fuses. Mine was so corroded it fell apart.
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
