No electric 12v power to the cab
   / No electric 12v power to the cab #31
Sorry for repeating myself but make sure the cab is grounded. Should have a ground strap from engine to cab.
Ok I’ll chk
   / No electric 12v power to the cab #33
Here's another PDF file I found in the which I believe what Harleycb had mentioned in his post. Bad picture but its does show some large fuses in the parts listing.
  • Illustration_04092021.pdf
   / No electric 12v power to the cab #34
Have you checked out the ignition switch? Voltage to the switch? Voltage coming out of the switch?
   / No electric 12v power to the cab #35
Your issue sounds just like what happened to me when I had to work on the starter. On the positive side of the battery cable you have two wires coming off. The thick one goes to the starter, the other smaller one should run underneath the radiator. Follow that back and there is likely a bad connector within 10 inches of the battery. It's a plastic blade connector that splits that small wire into two that feed the main fuses. Mine was so corroded it fell apart.
John Deere 5425 4x4 Tractor with Loader (A51573)
John Deere 5425...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
