No electric 12v power to the cab
   / No electric 12v power to the cab #31
Sorry for repeating myself but make sure the cab is grounded. Should have a ground strap from engine to cab.
Ok I’ll chk
   / No electric 12v power to the cab #33
Here's another PDF file I found in the which I believe what Harleycb had mentioned in his post. Bad picture but its does show some large fuses in the parts listing.
  • Illustration_04092021.pdf
   / No electric 12v power to the cab #34
Have you checked out the ignition switch? Voltage to the switch? Voltage coming out of the switch?
   / No electric 12v power to the cab #35
Your issue sounds just like what happened to me when I had to work on the starter. On the positive side of the battery cable you have two wires coming off. The thick one goes to the starter, the other smaller one should run underneath the radiator. Follow that back and there is likely a bad connector within 10 inches of the battery. It's a plastic blade connector that splits that small wire into two that feed the main fuses. Mine was so corroded it fell apart.
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2016 FREIGHTLINER...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
gravely riding mower (A53424)
gravely riding...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
