Mechanos
Re: No. 7 fronthoe???
Many thanks!!
Base plate: 3/8" thick, 4" x 7 1/4" Baseplate u bolts are offset from center of baseplate: first hole 1 3/8" from inside side of plate edge, outside hole is 3 3/8" from inside edge of baseplate. U bolts holes start 5/8" back from front edge of baseplate. U bolts are wrapping around the 2 1/2" square steel tubing that carries the FEL. Baseplate inside edge is 2 5/8" from tractor frame rail, extending 4" out on the 2 1/2" square stock from there.
Outer hole: 1.145" diameter Pin: 1.125"
Inner hole: .885" diameter Pin: .875"
Hole center is 1 5/8" down from the top of the baseplate, about 1 1/4" down from bottom of baseplate.
Mounting ears are 1 3/8" apart, inside to inside. Ears are 1/2" steel. Outer ear is bent to outside at bottom, overall it is 3 1/2" from bottom of ear to bottom of baseplate. Inner ear is 2 7/16" from bottom of base plate to bottom of ear. The inner ear measures 3 1/2" from its inside to the tractor frame rail.
Picture 416 shows the bent outer ear best.
Picture 417 is an angled from the rear shot, with an optical illusion making the inside u bolt look like it comes thru at the nearest corner. The mmm mounting in the background is distracting too. This picture sucks.
Picture 418 shows the bent outer ear and the u bolts.
The u bolts are somewhat offset from the baseplate to avoid the ears underneath; therefore there is a left and right mirror image baseplate. You can see how far from the inside edge the 1st u bolt is from the baseplate edge( about 1 3/8" inches in picture 415.
Many thanks!!
