No. 7 backhoe on a 955
/ No. 7 backhoe on a 955
Re: No. 7 fronthoe???
Base plate: 3/8" thick, 4" x 7 1/4" Baseplate u bolts are offset from center of baseplate: first hole 1 3/8" from inside side of plate edge, outside hole is 3 3/8" from inside edge of baseplate. U bolts holes start 5/8" back from front edge of baseplate. U bolts are wrapping around the 2 1/2" square steel tubing that carries the FEL. Baseplate inside edge is 2 5/8" from tractor frame rail, extending 4" out on the 2 1/2" square stock from there.
Outer hole: 1.145" diameter Pin: 1.125"
Inner hole: .885" diameter Pin: .875"
Hole center is 1 5/8" down from the top of the baseplate, about 1 1/4" down from bottom of baseplate.
Mounting ears are 1 3/8" apart, inside to inside. Ears are 1/2" steel. Outer ear is bent to outside at bottom, overall it is 3 1/2" from bottom of ear to bottom of baseplate. Inner ear is 2 7/16" from bottom of base plate to bottom of ear. The inner ear measures 3 1/2" from its inside to the tractor frame rail.
Picture 416 shows the bent outer ear best.
Picture 417 is an angled from the rear shot, with an optical illusion making the inside u bolt look like it comes thru at the nearest corner. The mmm mounting in the background is distracting too. This picture sucks.
Picture 418 shows the bent outer ear and the u bolts.
The u bolts are somewhat offset from the baseplate to avoid the ears underneath; therefore there is a left and right mirror image baseplate. You can see how far from the inside edge the 1st u bolt is from the baseplate edge( about 1 3/8" inches in picture 415.
Many thanks!!
Ok rabtfarm, one more dimension please. There is a link that attaches to the tractor's top link mount... the other end has two pin holes in it. Could you measure the center to center distance of the pin hole at the tractor's mount and either of the other two holes?
Thanks
Well, looks like I've had a stroke of luck. I started inquiring into the back story on this hoe with the seller. The tractor and hoe used to belong to the seller's neighbor's sister's husband. When he passed, his sister gave the tractor and hoe to him. He had no use for the backhoe and sold it to the guy I bought it from. From what the seller (guy I bought it from) told me, his neighbor is not the most mechanically inclined, so he just brought the tractor over and the guy I bought if from remove the hoe. Since he was not intending to use it on a JD tractor, he didn't think about removing the front mounts as he had no use for them. To make a long story short, I got the phone number of the neighbor that used to own the hoe and gave him a call. He still has the tractor and the front mounts are still bolted to the loader bar. He said I could have them, so I offered to remove them for him. I'm supposed to go over there tomorrow sometime and get the mounts. That saves me quite a bit of money/time.
/ No. 7 backhoe on a 955 #24
Center to center looks like 8 3/4". (If the link is still missing too). There is a second link hole(longer) but it is not used in my set up.
Thanks. That link was also cut in half and modified when I bought the backhoe. I've got put back where I thought it should be (best guess) and it is considerably shorter than that. Anyway I could get you to double check or confirm that measurement? I don't want to weld it back together at the wrong length.
You should be using that second hole as well. Once you get the link pinned to the tractor, you're supposed to put another pin through that second hole. This locks the link making it rigid between the tractor and the backhoe. Without that second pin, the link will just hinge in compression.
Score!!!
I met up with the previous previous owner tonight and removed the front hangers from his 855. He had it all set up for me on a concrete floor with a sheet of plywood laid on the floor and drop light under the tractor. Took less than 10 minutes and saved me a bunch of time and money.
I've got the subframe welded back together and the toplink bar prepped and ready to be welded.
Won't be long now and I'll actually get a chance to mount this thing and play with my new toy.
Finally got a break from this blasted 100+ degree heat. Got the top link welded back together.
Still waiting on a couple of miscellaneous parts from JD to show up... then I will be able to mount up the hoe and move it into the barn so I can get to work converting the controls from ISO to SAE.
Made some more progress tonight... my parts came in from JD and I got the mounts bolted up and hung the subframe to align the front mounts and make sure it was all going to fit up right after welding the subframe halves back together. Fit like a glove. I just need to bolt the subframe back to the backhoe and I'll be ready to mount it up. Hopefully I'll get a chance to do that tomorrow night.
/ No. 7 backhoe on a 955 #29
Hi all
Curious roughly how long it takes you all to install / remove the #7 backhoe?
She's a good lookin' hoe, isn't she...
It took me a while, but I finished putting assembling the 7BH tonight and got it mounted. I had to drop the subframe, then go hook up the BB for ballast. Picked up the hoe with the loader and move it off the pad I had it stored on and set it down by the subframe. Then go drop the BB and remove the 3pt hitch arms. Pulled the tractor up to the hoe and hooked up the hydraulics so I could use the boom, bucket and stabalizer to position the hoe correct to facilitate bolting up the subframe. Then the unhooked the hydrauilics and moved the tractor out of the way so I could bolt up the subframe. Once that was done, I was ready to actually mount the hoe for the first time.
Mounting the hoe was incredibly simple, easy and quick. Back the tractor over the subframe, hook up the hydraulic lines, use the boom and the stabilizers to raise the hoe up to line up the subframe with the rear hangers, back the tractor up to engage the subframe with the rear hangers, raise the boom to pivot the front of the subrame up to engage the front hangers into their brackets, install the front hanger pins, move the toplink into position and pin it place. Done. Took five minutes or less to mount the hoe... probably took me longer to type out the process than it did to mount it.
I'm definately going to have to put my tall rops back on though. When I got the tractor, it had the tall rops on it but since I didn't have a BH, I took it off and swapped on a regular rops. When I sit on the BH seat there is about a 1/2" between the top of my head and the bottom of the rops... that's a headache waiting to happen.
Hi all
Takes about 5 minutes to mount or remove the #7 on the x55 series. The mounts for 750 are a little different so I can't speak for how long it takes to mount or remove on that series tractor.
/ No. 7 backhoe on a 955 #32
Hi.
The former owner of my JD750/#7 backhoe also took of the seat assembly
Curious if perhaps you may be interested in selling yours as I'd prefer to have a seat back there?
Hi.
Sorry, I perfer to sit.
/ No. 7 backhoe on a 955 #35
Hello.
I think my first post
I have a 955 with model 40a loader and today I located and bought a Model #7 backhoe in great shape with subframe (and second owner) - I do have to instal Power Beyond on 955 - which I knew when I bought it because I do not have it. (Any/all advice appreciated with Power Beyond) - in particular is there only one Power Beyond kit - or are they tractor specific?
And
now that I am looking in this forum and trying to figure how it gets mounted it appears from photos posted that I need to go back and ask for the rear hangers (I think previous owner had it on an 850) - and front hangers? (I have 60” mid mount mower deck - is where the drag arms of deck mount what front pins mount to?) what else do I need to ask for (or get/ make if 850 is different from 955) off his tractor to make it mount onto 955. Thank you in advance.
Looking forward to having Model 7 for light landscaping/ trenching. Not commercial - occasional yard work.
Again thank you.
/ No. 7 backhoe on a 955 #36
Hello.
And
Again thank you.
You do know that you are responding to an 8 year old post?
/ No. 7 backhoe on a 955 #37
fried1765
:welcome: to TBN
Ok to bring up old posts, and hope you get some help with mounting the model 7. Post up some pics of what you have. We like pics.
The power beyond kit likely not available, but am sure some searching here on TBN (using the google search button up top works best for me) will find some previous posts on adding the power beyond. Have to dig around under the seat to connect into the right lines I believe. And order individual parts if available.
Lots of talent on TBN to give you a hand.
/ No. 7 backhoe on a 955 #38
Hi GBB, You are in luck, as I just bought another 955 without the backhoe, so I can directly compare the two. There is a front and rear mounting bracket and tapered pins (2) that hold the forward frame of the backhoe. You will need the power beyond kit that attaches to the hydraulics of your tractor under the seat. I removed the backhoe seat as I find it is just easier to twist around and run the controls from the main seat. Not terribly comfortable, but you will find when trenching that you need to move so often that it's much easier to skip the climbing from the main seat to the backhoe seat and back every 5-10 minutes. Deere should have come up with a swivel main seat there. I will take some pictures of both so you can see the differences. Lastly unless you have some real projects in mind(I have ran 275 feet of electrical power trench and two foundations, plus stump removals and burying two horses with the backhoe) but as an attachment it will sit more than dig, so save yourself the $ and rent whenever you feel the urge to dig. The parts you need will total over $1500; some may be difficult to even obtain. Front Left backhoe mount.JPGPower Beyond hose coupled.JPGPower beyond with hose uncoupled.JPGRear backhoe mount.JPGTop view front right backhoe mount bracket.JPG
/ No. 7 backhoe on a 955 #39
Here's the "new" 955 without the mounts or power beyond.IMG_6600.JPGIMG_6588.JPGIMG_6591.JPG
/ No. 7 backhoe on a 955 #40
Bear in mind that the 850 single rear mount is a different part number(PT 10466) than the 955 two parts ( AM 104207, 208).
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
