Nice little beginner welder
/ Nice little beginner welder
My friend has this model , i'm going to use, Look at the tip options, This is canada amazon , you can get it cheaper
25 Watt 510C/950F , Hope its strong enough, he only uses it to burn wood, can use to fix computers aswell, I can build gaming computers and over the years through away pricey motherboards and vid cards, with only a burnt fuse i bet or a diode, might buy one
At 120volts Just tried 3/32 rods and at 100 amp setting burned a full rod and breaker tripped right at the end with a 15 amp breaker, thats about 2000watts, 20 amp breaker is about 2400 watts
Burned threw bed frames and thats kinda hard steel for 1/8 , great little welder , hope it lasts
/ Nice little beginner welder #23
The Tooliom in Post #1?
Yes, Im plugging in a shed soon so if I can burn 3/32 at 120volts il be happy, I got a 20 and a 30 amp single pole breaker I can use, tried it at a friends house today , wires in my walls are to small was scared to try, with 400 more watts with a 20 amp breaker i should be fine, im using 10 wire
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
