Nice cheap back blade for BX!
/ Nice cheap back blade for BX! #1
proudestmonkey
Platinum Member
Cottage Grove, Minnesota
Kubota BX 2230
A few weeks ago, there was a thread about which blade would be good for a BX. Timing was perfect, because that's what I was looking for.
I ended up buying the standard duty back blade made by King Kutter (not the smaller and lighter XB blade and not the heavier "Professional Series" blade). I bought a 60" at TSC for $215. What a great blade for the price. I couldn't put it on when I bought it because the weather was too wet to do anything with it. Today was the first chance I had to put it on and play with it.
I was worried because a local dealer thought a standard blade would be too big for my BX, but I didn't think the smaller "estate" series Woods or the XB series from King Kutter would be heavy enough to drag dirt and gravel when doing grading work. Now that I have this blade, I think I was right (see below).
So, the blade I bought worked just great. Its probably better adapted to tractors that have a higher 3 pt hitch (when you have rear hydraulics in the very lowest position, the blade tilts forward a bit). Other than that, it seems perfect for what I want to do, and lifting the blade by a few inches remedies the situation because the blade straigtens out. I am very glad I bought it. Its plenty heavy, its not really too big, and it extends far enough back so you can change it from forward to reverse without taking it off (another reason I am glad I went with the 60").
I used the blade to dress up my gravel driveway, which was in very bad shape. Up until now, we've been hand raking it, which takes about an hour to an hour and a half. I did the same amount of work in 5 minutes, and after 30 minutes of fine tuning, the driveway is smoother now than its been since we paid someone to spread three dump trucks full of class III and class V (clean) gravel a year and a half ago. I rolled the newer gravel with the older base of Class V and limestone powder to make a more stable mix. Tommorrow its supposed to rain, so I am going to go over it with my water-filled lawn roller to pack it down before we start to get frost (which will hopefully lock it in for the winter).
I also finally have a smooth trail to the tractor shed. Earlier this year we got a short deluge of rain that washed several very long and fairly deep ruts in the trail (which is about 200 feet long). On my way to put the tractor away, I let the blade down all the way, so it was floating over the loose stuff, which then rolled into the ruts. Without hardly slowing down, I had accomplished in no time at all something I have been wanting to do, but unable to do, all summer long. Doing both jobs, I can see that a blade any lighter than the one I got (250 lbs) would probably be too light. As it is, I had to go over some areas a few times to get enough of the gravel "rolling" ahead of the blade to properly fill in low spots.
This blade meets everything I was looking for: size, versatility, durability, and very low cost (I still can't believe they can make a profit selling this much iron for such a low price--I figure shipping alone has got to be very pricey).
Given its size, and maneuverability, it should be perfect for snow plowing.
The only downside I can see is that, with the length of the back blade plus the added length of the FEL, I will no longer be able to put the tractor in the shed (the FEL is not on yet).
/ Nice cheap back blade for BX! #2
Cool - I bought the 48" XB Box Blade for my BX24... and ever since then it has rained, rained - did I mention the rain...
Here's what I did with mine before it was vanquished to the back of the lot - due to rain.
Lifted it out of the truck with the FEL - attached it to the 3PT - dropped the scarfers - ripped up some of the asphalt in my driveway (intentionally) - smiled that I got 15% off on the BB because it "looked beat up" at TSC - drove it out back and parked it where it sits today.
Seemed heavy enough to rip on the driveway... but then again, I don't know that you need the weight for a BB as much as a straight one since the scarfers pull the blade downward... If it ever dries out before the ground freezes - I'll let you know how the "blade" functionality works.
I would have liked a 60" jobber - but I was cautioned against anything larger than 48" when it come to a ground engaging implement on my BX24.
Even in terms of a straight blade?
My Kubota dealer specifically suggested 60" as the optimum-sized back blade for my BX. They wanted to sell me a Bush Hog brand one for nearly $600. They are great guys, but I am very glad I went to TSC--saved me nearly $400.
/ Nice cheap back blade for BX! #4
I have a 5 ft King Kutter box blade on my BX and it is too much. Since I have it, I use it, but for doing a lot of BB work, a 4ft would work better.
It sure works well as rear ballast for FEL work.
Ron
Ron
With a box blade, I can see 5 feet being too much. With a straight blade, I would think it would be tough to find one that is 4", and it would probably also be too light.
/ Nice cheap back blade for BX! #6
I have a cheap Farm Star that I picked up when Central Tractor was going out of business, I got the 7', didn't want one that big, but that was all they had and I only use it for snow on my asphalt driveway. It works well for that since we usually don't get a lot of really heavy snows here and I can turn it around without hitting anything also, but I do have the Pats Easy Change on the lower lift arms that make them almost 4" longer, next time I have the blade on, I'll see if I have enough clearance to turn it if the PEC was not on there, works for me, I also use a 4' box blade that works well and it is all that I have traction enough to pull when it is full.
/ Nice cheap back blade for BX! #7
Never really thought about it - just kinda operated on the 48" rule of thumb. I suppose I see how a straight blade wouldn't "bit" like a plow, tiller, BB or other real ground engager... Now - I'll have to talk to the wife about testing this theory with a 5' blade... :)
I suppose a straight blade is more likely to "float" than bite - good thought.
/ Nice cheap back blade for BX! #8
My experience is, if you want "aggressive", use a straight blade. The sides of a box will mitigate grabbing. A straight blade will dig to China, in optimal soil, when it gets hooked up.
It isn't the width of the blade that's the prob, it's the amount of material that it drags along. With gauge wheels controlling the cut, I can pull a full box and have dirt rolling out the top BUT, it takes reduced tire pressure, a lot of throttle and tire slippage. Not worth it. Agree that I could never pull a 5' box.
My 5' straight blade works well. I could probably use 6' but my operations are such that 5' is max desirable. 5' allows rotating the blade one notch to create wind rows and still be wider than the tires. I can't even use it without gauge wheels, it's so grabby.
I have a 6' rake that pulls fine. It seems a bit wide for the weight of it and is many times wider than my needs.
/ Nice cheap back blade for BX! #9
Same blade I run on my B3030. Not the best in the world...but its cheap and does what I expect of it! Dont know how a guy can go wrong with one unless he needs all the tilt / offset feature of the more $$ blades...which I dont.
HomeBrew2 said:
My experience is, if you want "aggressive", use a straight blade. My 5' straight blade works well. I could probably use 6' but my operations are such that 5' is max desirable. 5' allows rotating the blade one notch to create wind rows and still be wider than the tires. I can't even use it without gauge wheels, it's so grabby.
When I dressed up the gravel last night, I put the blade in reverse position (curved side facing behind the tractor) and then pulled the tractor forward, to drag the gravel instead of cut into it. I also went once over the gravel the first time with the blade about 1 to 2 inches above a flat service (so it wasn't floating) so it would fill in all the little low points a bit. Then I went over it a second time in float.
2015 Cadillac ATS Sedan (A59231)
2015 Cadillac ATS...
2005 Cummins Onan DGCB-5736453 75kVA 3-Phase Diesel Generator (A59228)
2005 Cummins Onan...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59906)
2013 GREAT DANE...
