NH68 feed "rice fork" hitting frame
   / NH68 feed "rice fork" hitting frame #1
petebert
Outside of Ann Arbor
The red feed fork is hitting the frame on the downward stroke. Bandaid fix would be to cut a notch where it's been hitting. Any ideas for an actual fix? There's a nut pictured below on top of the rail that the feed forks are on. I found that completely loose. If I tightened that I could see it raising it a couple millimeters. Maybe a couple more if I replace the roller bearings. Aside from that I don't see anything to adjust.
After posting this I researched it some more and have a theory. I actually have a 2nd problem also, the feed fork bar is hitting the machine at the top of it's stroke also. While looking into it more and seeing pictures of other peoples balers I noticed the spring loaded bar at the end of mine sticks out further than on other peoples. I don't see anything in the manual on the correct distance to set this thing at but am thinking if I wipe all the junk off of it I mind find a mark or at least a rust line from where it previously sat.
   / NH68 feed "rice fork" hitting frame #3
Maybe. Thank you for the information. I am not an expert but your words make sense.
Tafe 45DI (A60462)
Tafe 45DI (A60462)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
John Deere 4520 (A60462)
John Deere 4520...
Year: 2017 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 137,045 Plate: Body Type: 4 (A59230)
Year: 2017 Make...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
