NH TC45D Starter sticking, etc
   / NH TC45D Starter sticking, etc #1
Bookemdanno
West Georgia
NH TC45D
I have a NH TC45D with a hydrostatic trans. Recently the starter has been staying engaged after cranking the engine and occasionally it will re-engage after the engine is already running. Usually, if it stays engaged or re-engages, it will disengage when you put the trans in gear. If you then put it back into neutral, usually the starter will remain disengaged, but sometimes it will re-engage. Usually, if you turn the engine off and re-start it, the starter will remain disengaged. The starter recently re-engaged while I was warming up the tractor and briefly went inside - the starter stayed engaged long enough to burn it up (the starter, not the tractor thank God). - So, I have installed a brand new starter (with solenoid) and still occasionally run into the same problem with the starter re-engaging on its own. - Has anyone else had this same problem and what is the fix for this. I have checked wiring and gotten a few suggestions, but nothing thus far has fixed it.
Thanks in advance for your suggestions.
   / NH TC45D Starter sticking, etc #3
Just a guess, but since you replaced the starter and solenoid, that leaves the key switch as another essential component to that loop. There have been numerous switch issues reported on here, although I don't remember any that were shorting and engaging the starter.
That is one of my guesses too and sounds reasonable. I am trying not to just throw parts at it until something works - some of the other suggestions have been off the wall and rather pricey..... Thanks Ford 850.
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2020 DRAGON ESP...
SCAN TO RECEIVE TEXT UPDATES (A52708)
SCAN TO RECEIVE...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
