NH TC45D Starter sticking, etc
   / NH TC45D Starter sticking, etc #1
Bookemdanno
West Georgia
NH TC45D
I have a NH TC45D with a hydrostatic trans. Recently the starter has been staying engaged after cranking the engine and occasionally it will re-engage after the engine is already running. Usually, if it stays engaged or re-engages, it will disengage when you put the trans in gear. If you then put it back into neutral, usually the starter will remain disengaged, but sometimes it will re-engage. Usually, if you turn the engine off and re-start it, the starter will remain disengaged. The starter recently re-engaged while I was warming up the tractor and briefly went inside - the starter stayed engaged long enough to burn it up (the starter, not the tractor thank God). - So, I have installed a brand new starter (with solenoid) and still occasionally run into the same problem with the starter re-engaging on its own. - Has anyone else had this same problem and what is the fix for this. I have checked wiring and gotten a few suggestions, but nothing thus far has fixed it.
Thanks in advance for your suggestions.
   / NH TC45D Starter sticking, etc #3
Just a guess, but since you replaced the starter and solenoid, that leaves the key switch as another essential component to that loop. There have been numerous switch issues reported on here, although I don't remember any that were shorting and engaging the starter.
That is one of my guesses too and sounds reasonable. I am trying not to just throw parts at it until something works - some of the other suggestions have been off the wall and rather pricey..... Thanks Ford 850.
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2014 JCB 930 (A53317)
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
