NH TC30 Hydraulic Remotes
   / NH TC30 Hydraulic Remotes
Hey guys!
Been trying to get some info from my dealer as well as some others. They're still checking on adding power-beyond. I'm limited to 1 rear remote. They also think I might be limited by pump output on the ability to running additional cylinders. Maybe I'll hear something more definate this week. If I can only run 1 rear remote without a power-beyond from that maybe I would be best to use the FEL power-beyond for the joystick valve for the T-N-T. Then I wonder if it's even worth adding the rear remote for the woodsplitter etc.
   / NH TC30 Hydraulic Remotes #12
That's a load of BS...you can add 100 cylinders to your machine-you can't use them all at once but you can still add them.
You already have that-that what you hook your splitter to.
Yeah that's what I thought Kenny. I'll wait awhile to see if I get any other input. You think it's worth adding the single rear remote if that's all that's available or just using the FEL power-beyond for the T-N-T/woodsplitter? Maybe I could use the rear remote for Top and run a dual purpose valve off the FEL for TILT and to use with the woodsplitter? Still like the joystick idea better.
   / NH TC30 Hydraulic Remotes #14
Forget the dealer and the single remote. You should add a new joystick valve ($200) to your existing PB loop (probably $200-$300 in hoses, fittings and QD's) for your TnT setup. You will get exactly what you want and not have to settle for less.
Kenny
I spoke with another dealer. He said it's possible to stack the remote blocks together to get two remotes. The issue would be fender clearance. He said they're about 8" stacked. I have just enough room, then I would need to deal with lever placement and remote outlet routing since they come with the same piping. Do you think that's worth pursuing at $450/remote or not?
thanks again Matt
28013 (A50322)
28013 (A50322)
METSO AUTOTEC NORDTRACK I1011 MOBILE CRUSHER (A51242)
METSO AUTOTEC...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
377811 (A48836)
377811 (A48836)
Noble 8 Row Cultivator (A50514)
Noble 8 Row...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52128)
2023 New Holland...
