NH 665TL Loader Problem
/ NH 665TL Loader Problem #1
coolnature
Tennessee
NH T4.95, Kubota RTV X1120D, Ford '52 8N
I have a NH T4.95 w/ 665TL FEL. When raising the loader at about the mid point, it hesitates and slows down, but not fully stopping, then continues upward as it should. The curl function works as it should. The 3PT lift works as it should. I did have a WR Long 3rd function installed before taking delivery when I bought the tractor, but have not used the 3rd function yet. It is still under warranty and will be taken care of by the dealer. Anyone know what could be the cause? Thanks in advance.
/ NH 665TL Loader Problem #2
Sounds like air in cyl.
Cycle loader up/down about 10 times with relief and see if it still does the hesitation.
Thanks JJ. I have cycled it 2-3 times and thought that would be enough to get any air out.
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
