NH 1925 hst what is the clutch pedal for ?
   / NH 1925 hst what is the clutch pedal for ? #1
Sprinklerman
Platinum Member
severna park
New Holland 1925 Kubota bx 24
I have been playing with my new toy , but for the life of me I have no clue what the pedal on the left is for . I am guessing it is the clutch . But its a hydrostatic machine . Maybe for the 3 point ? I am also curious if the hydrostat is seperate from the hydraulic oil?
   / NH 1925 hst what is the clutch pedal for ? #2
Do you have a low, medium, and high range hst? Clutch would be for disconnecting the engine so you can shift.
Manual should tell you about the hydro/hydraulic oil. Most hydrostatic units I have seen are combined.
It does have 3 ranges , The guy I bought it from is looking for the manual , I thought it was strange that there was a filter for the hydraulics , and another for the HST .
   / NH 1925 hst what is the clutch pedal for ? #4
Most Kubotas have two filters as well. One is a hydraulic suction filter, the other is for fluid the HST. Someone may have schematics that give more detail. Same fluid in a single reservoir for both hydraulics and HST.
   / NH 1925 hst what is the clutch pedal for ? #5
I had a Mahindra 2615 HST. It also had a clutch pedal. My main clutch use was for engaging the PTO slowly.
   / NH 1925 hst what is the clutch pedal for ? #6
It is the clutch for shifting ranges and engaging ptos. Probably a common sump for hydraulic oil with two filters, at least that's what mine has.
   / NH 1925 hst what is the clutch pedal for ? #7
PTO and range gears would grind pretty bad even at idle without a clutch.
   / NH 1925 hst what is the clutch pedal for ? #8
On my TC 29d the PTO's need the clutch. However I have found that changing ranges sometimes feathering the clutch allows it to change easier and faster.
   / NH 1925 hst what is the clutch pedal for ? #9
Shifting, PTO engagement, and starting interlock on some tractors, just like a stick shift car.
thanks
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
