NH 1925 hst what is the clutch pedal for ?
   / NH 1925 hst what is the clutch pedal for ? #1
Sprinklerman
severna park
New Holland 1925 Kubota bx 24
I have been playing with my new toy , but for the life of me I have no clue what the pedal on the left is for . I am guessing it is the clutch . But its a hydrostatic machine . Maybe for the 3 point ? I am also curious if the hydrostat is seperate from the hydraulic oil?
   / NH 1925 hst what is the clutch pedal for ? #2
Do you have a low, medium, and high range hst? Clutch would be for disconnecting the engine so you can shift.
Manual should tell you about the hydro/hydraulic oil. Most hydrostatic units I have seen are combined.
It does have 3 ranges , The guy I bought it from is looking for the manual , I thought it was strange that there was a filter for the hydraulics , and another for the HST .
   / NH 1925 hst what is the clutch pedal for ? #4
Most Kubotas have two filters as well. One is a hydraulic suction filter, the other is for fluid the HST. Someone may have schematics that give more detail. Same fluid in a single reservoir for both hydraulics and HST.
   / NH 1925 hst what is the clutch pedal for ? #5
I had a Mahindra 2615 HST. It also had a clutch pedal. My main clutch use was for engaging the PTO slowly.
   / NH 1925 hst what is the clutch pedal for ? #6
It is the clutch for shifting ranges and engaging ptos. Probably a common sump for hydraulic oil with two filters, at least that's what mine has.
   / NH 1925 hst what is the clutch pedal for ? #7
PTO and range gears would grind pretty bad even at idle without a clutch.
   / NH 1925 hst what is the clutch pedal for ? #8
On my TC 29d the PTO's need the clutch. However I have found that changing ranges sometimes feathering the clutch allows it to change easier and faster.
   / NH 1925 hst what is the clutch pedal for ? #9
Shifting, PTO engagement, and starting interlock on some tractors, just like a stick shift car.
thanks
1983 KENWORTH W900 SLEEPER (A58018)
1983 KENWORTH W900...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2010 Dodge Grand Caravan (A56859)
2010 Dodge Grand...
