Newly Rebuilt Tractor Overheating
/ Newly Rebuilt Tractor Overheating #41
Well pointing fingers at the head gasket is a dead end, the temp readings don't indicate a true overheat, and the cooling system doesn't seem to have any flow restrictions. It's time to open up the range of possibilities.
It sure wouldn't be the first time a Yanmar/Deere engine cracked a head.
/ Newly Rebuilt Tractor Overheating #42
Yeah Kenmac is right he did say the head was done at a machine shop it was surfaced and valve job done doesn't mean they didn't miss something but at least someone has looked at it.
He was originally talking about excessive coolant overflow along with what he perceived as overheat which most of us said the temps he was seeing were not overheat. The overflow would indicate the head gasket was not sealing and that's where we got on the mis-torque ideas.
/ Newly Rebuilt Tractor Overheating #43
I agree, Head could be cracked. I was just pointing out that, in another thread he had some head work performed.I think he's had a couple threads on this tractor
/ Newly Rebuilt Tractor Overheating #44
I've seen heads that were pressure checked (cold) and magnafluxed that ended up being junk because of cracks in obscure places. They only opened up at operating temps.
It doesn't have to be somebody's "fault".
/ Newly Rebuilt Tractor Overheating #45
This is true Rick anything is possible never say never they say. :thumbsup:
/ Newly Rebuilt Tractor Overheating #46
Sounded like an exhaust gases leak due to an improperly torqued head gasket; no one's fault, just cause and effect. Once you retorqued the problem seems to have resolved itself so far. I'd personally go back after about 50-100 hours and see where the head bolts are at that amount of use. I also wouldn't try to make it blow up by running it as hard as possible until it has some medium duty hours on it, assuming you want it to last.
What are you using for a torque wrench? A bar with dial indicator or a set to # and listen for click type? I was surprised recently to find the most accurate are the older type pointer on dial, NOT the set and click type. Try another torque wrench, just for comparison and see what results you get.
I would not use anti-seize of any kind on a head bolt. I wire wheel them until clean, lightly oil and then dry excess oil and torque 'em down.
/ Newly Rebuilt Tractor Overheating #47
I'm with you on the anti-seize. Back in the day I owned a drag car. I always used a small amount of oil on the head bolts and torqued them down. Cranked the engine and let it run for a period of time and re- torque
/ Newly Rebuilt Tractor Overheating #48
Oil,Yes, anything else throws off the actual torque readings.
/ Newly Rebuilt Tractor Overheating #49
I had a chart one time that showed how different types of lubes affected clamping force. I don't remember the actual numbers but I do remember the difference was amazing. Even just different weights of motor oil made a few lbs difference.
/ Newly Rebuilt Tractor Overheating #50
Yeah oil is the best on a blind hole but sealer is required on wet holes like Chevy v8's etc even it has anti friction quality's better than dry or dirty AND dry. You HP guys already know arp uses a moly lube on their fasteners.
You can feel when a bolt or nut is tight its not rocket science. Torque to yield is the exception but we dont have them on tractors thank goodness.
/ Newly Rebuilt Tractor Overheating #51
The Yanmar being repaired isn't a V-8 Chevy or other specialty car application with moly lube needed to fasten the head to the block- it's just a basic tractor, no frills. Oil and go.
/ Newly Rebuilt Tractor Overheating #52
We are having a friendly conversation is that ok with you?
/ Newly Rebuilt Tractor Overheating #53
I "always " run a head bolt through the block holes and check the threads before I even Think about installing the Gasket/Head esp. if you can see it. Hit them with a orbital brush and clean up the threads. Blow them out after finishing the resurface Clean or New Bolt and you won't have any problem.
/ Newly Rebuilt Tractor Overheating #54
The OP has already installed the bolts with anti-sieze its already a done deal so hopefully he will learn from our posts for the next time. That's my intentions as always try help someone for the next time if I cant this time. ;)
/ Newly Rebuilt Tractor Overheating #55
He's had a rough time with this tractor. Let's hope he's got her repaired / fixed this time
/ Newly Rebuilt Tractor Overheating #56
Torque-to-yield fasteners have been used in (some) ag engines since at least 1987.
I appreciate everyone's input. We all have opinions. I used to work for A W Chesterton. We supplied the Navy with Nickel Anti-seize and they spec'd it on their valve assemblies and used it in their assemblies on motor and engine rebuilds. I was schooled by Chesterton's engineers and told to use anti-seize on anything that had a chance of rusting together and just watch tightening since you could reduce the required torque by 15-18% depending upon the application and if the assembly was listed with oiled bolts or dry on initial installation. When I removed the head bolts the first time I had to use a 4' breaker bar on 2 of the bolts and heard the perverbial snap when they finally let loose. Upon inspection I could see that the bolts had dry rust residue on the threads. I was determined not to ever have to deal with that situation again. For those that didn't see my previous post when I rebuilt the tractor I had to use Hoye's injector puller and it took 40-50 whacks on the slide hammer to get the injectors to pull out. Needless to say I cleaned and coated both the head and the injector with nickel anti-seize, even though they don't touch, they won't get the particles in between and rust in place like they were going forward. Car Doc's question about the sleeve liners sticking up slightly got me thinking and I don't remember if they were slightly higher or not. The motor wasn't overheating prior to the valve seat letting go and damaging everything so I just assumed redoing the head would solve the problem along with the new piston and new rings in each cylinder. I included a pic of the damaged piston on #1 cylinder, when I first tore it apart. Again thanks to everyone for their comments and suggestions. SDC10126-1024.jpg
/ Newly Rebuilt Tractor Overheating #58
Those liners look a few thousanths higher to me at least from the pics at least which is not the best angle to notice such a thing?
/ Newly Rebuilt Tractor Overheating #59
Interesting wonder why are they using aluminum heads on ag engines now and who is doing it? They are a complete joke in the automotive industry fwtw. I could have said and will say in the future we dont have to deal with them on OLD tractor engines! :laughing:
/ Newly Rebuilt Tractor Overheating #60
Ok I remember this engine now after seeing the valve seat disintegrated pic I talked to you then also.
I am slow sometimes yes it does appear there is some protrusion on the liners and there doesn't appear to be any gasket sealing issues either pre-disaster so that is probably ok. I may have mentioned the actual spec at the time you tore it down and what to look for?
I sure done remember now but that's water under the bridge I just hope she is sealed up now so you can get back to work. :thumbsup:
Ford Tractor (A62613)
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
Ingersoll Rand Roller (A64553)
Ingersoll Rand...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
1979 Log Trailer MODEL JCV040 40ft Long 65000 GVWR (A62679)
1979 Log Trailer...
