NewHolland 21D
/ NewHolland 21D #1
L98camino
Central Wa.
None
Hey guys, had an accident and had to leave the tractor on it’s side on a downhill slope for a few days. Got it hauled up yesterday. What kind of precaution should I take before trying to start it.
thanks, Dan
/ NewHolland 21D #2
thanks, Dan
Check all the fluid levels (engine oil, coolant, fuel, transmission fluid and hydraulic fluid, front axle fluid, battery electrolyte). Top off as required. Pull plugs or injectors to make sure that there is no oil in cylinders. If there is, crank to clear and re-install plugs or injectors.
Check all the wiring connectors and look for broken wires. Repair as necessary.
Check engine control linkage for damage and restore.
Bleed fuel delivery system if you have a diesel. Then try to start.
Look for fluid leaks and damaged components.
/ NewHolland 21D
Trying to register with MyNewHolland.com. Need some service info but the site won’t take any of the numbers I have found.
2006 TC21D
/ NewHolland 21D #5
What are you trying to find on MyNewHolland.com? You don't need to register to get most everything on there
/ NewHolland 21D
The site requires serial number and it won’t take any of the numbers I have
/ NewHolland 21D
I’m looking for service manuals and part diagrams
/ NewHolland 21D #8
Operator Manual:
Service Manual:
Messick's normally has a good selection of parts and diagrams online:
/ NewHolland 21D #9
Just wondering, but it is a TC21D, not 21D. That might be the reason it won't take it
2013 JLG 8042 TELEHANDLER (A67714)
2013 JLG 8042...
JCT 72" Skid Steer Rotator (A64912)
JCT 72" Skid Steer...
2016 Ford F-750 (A64911)
2016 Ford F-750...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2015 JOHN DEERE 544K WHEEL LOADER (A65056)
2015 JOHN DEERE...
