NEWCOMMER
/ NEWCOMMER #1
LEODIGGER
Kubota L210 & kubota L245DT
Hi everyone,
I boughta my first Kubota 4 months ago. It was rusted into the ground and I boughta ita for two hundred dollars as a project for fun. I am now a collector and love working on the old thing. I stopped to speak to an owner of a L245DT and ended up buying that one too.
The rims on the 210 were rusted in half. I bought a set of rear rims out of Alabama and had to have the front rims made custom. I am nearing the completion of the L210 and am excited about starting on the 245.
finding parts have been the biggest challenge and I have had to make some of my old parts. I plan to post some PHOTOS of before and after photos in the future.
I read about a trick to remove heavy rust and it has worked.
put the rusted part in a plastic bucket of water, add baking soda then hook up a battery charger with the positive cable on a sacrificial piece of iron and the negitine clamp on the part to be treated then let the cahrger run for a few hours. I pulled the rim out and dropped it on the concrete and about 80% of the scale rust fell off.
Any words of wisdom or advise on where to find parts would be wonderfull.
THANKS FROM LEODIGGER!
/ NEWCOMMER #3
I apologize for the inability in providing you with info in regards to your parts inquiry, but I truly enjoyed the info about rust removal. I wasn't aware of that method. :):tractor::welcome:
/ NEWCOMMER #5
I've been a member here for only a couple months myself, but this is the best group of guys I've never met in my life! Very helpful and some pretty good fun.
I can't answer anything about your old iron, but welcome to TBN!
/ NEWCOMMER #6
...a sacrificial piece of iron...QUOTE]
I use rebar for that. Do NOT use any kind of stainless...makes poisonous gas. Baking soda alternative...Borax makes a washing soda. As for parts source, possibly salvage...search forum, there have been references to yards specializing in Kubotas...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
