Newby Question
/ Newby Question
You have to have the RPMs up so the PTO will spin the grinding wheel fast enough. Then the GPM is at the max. I had the flow restricted but that cause the pump to really squeal so I removed it.
/ Newby Question #12
Where did you put the restriction?
It should have gone after the work port and close to the cyl port.
You then only feed a little fluid to the cyl, and the remaining fluid from the pump just passes on to the tank.
/ Newby Question #15
If you have to have a joystick valve that valve is OK.
Here is the PB section.
http://www.surpluscenter.com/adspecs/AS9-8185.pdf
Here is an option for you.
A two valve solenoid 3rd function setup will give you a two cyl control, left/right, up/dpwn.
With this valve setup mounted on the tractor, you could stand off to the side with a 20 ft cable box with switches and control the stump grinder by pressing buttons or switches.
With a third cyl, you could go fwd and rev moving the stump grinder head.
Now, you have three planes.
/ Newby Question
I think the joystick would be easier to control the grinder, and take up less room when mounting. I want to mount it beside the seat, next to the stock rear remote lever. I was thinking of a diverter to control the side link, if/when I install. I will use the stock remotes for the top link.
KBH Tank Trailer (A61307)
KBH Tank Trailer...
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
(INOP) JOHN DEERE 450CE CRAWLER DOZER (A59823)
(INOP) JOHN DEERE...
CFG H15R (A60463)
CFG H15R (A60463)
