Tiller Newby question: Which is better forward rotating tiller or reverse?
   / Newby question: Which is better forward rotating tiller or reverse? #1
bboxall
LaFayette, GA
2017 Kubota B2601
I have a Kubota B2601 and I'm looking at a Woods RT48.30 tiller to make a garden. Which is better forward rotating tines or reverse rotating?
THANKS!
   / Newby question: Which is better forward rotating tiller or reverse? #2
this video from messicks' covers that well: YouTube
   / Newby question: Which is better forward rotating tiller or reverse? #4
Don't need no veeedeeoes......
Reverse rotating does a better job for the most part but takes more tractor since it's pulling the opposite direction of your forward movement. Forward rotation works fine, but ejects material behind. Still don't recall seeing one that does counter rotation like walk behinds.
   / Newby question: Which is better forward rotating tiller or reverse? #5
My FRT has been fine if you wait for the soil to be ready for tilling.
   / Newby question: Which is better forward rotating tiller or reverse? #6
Too bad they don't make a rotary plow like on a gravely or bcs for tractors. Seems a gang rotary plow would be the bomb!
Sorry this doesn't help.
   / Newby question: Which is better forward rotating tiller or reverse? #7
I have had both styles on the same garden tractor. If you want to incorporate a thick layer of mulch into the garden, get a tiller with forward rotation. If you want to till VERY hard ground, get a reverse rotation tiller but keep in mind, this type wants more horse power.
Does your cub cadet 2165 have a rear pto?
TractorData.com Cub Cadet HDS 2165 tractor information
Sorry bigtiller, my profile machine listing is out of date. The Cub Cadet is gone, I bought a new Kubota B2601 in 2017.
   / Newby question: Which is better forward rotating tiller or reverse? #9
I had a 8hp TroyBilt with forward rotating tines. On virgin ground you had to be careful. The tines would want to raise up on the virgin untilled ground and the entire tiller could take off. Like a wild horse. Once the ground was tilled - no problems. Yes - my ground can be very hard when untilled.
I've seen tillers that can be run forward or reverse. These are large tillers - requiring 60 to 75 hp tractors as a minimum.
   / Newby question: Which is better forward rotating tiller or reverse? #10
My forward has worked for me. I only know one person with a reverse and it cover the tractor all in dirt. I wouldnt want one.
John Deere 1025R (A53317)
John Deere 1025R...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
2003 Big Tex 10PI...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2007 Volvo VNL Truck Tractor (A56438)
2007 Volvo VNL...
MASSAGE CHAIR (A58214)
