MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,240
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
As far as leak down goes, I'd never leave an implement up in the air unattended, machine running or not. And I'd never get my body under an implement that wasn't supported by jacks or a chainfall/hoist, etc...
Mine will leak down with the engine off in about 10 minutes. With it running, I don't think it leaks down at all. Never timed it.
What I'd be most worried about is something happening to the joystick or its valve to release and the implement come crashing down and crushing me.
I do lift the mower deck all the way up and tilt it back, so I can grease the spindles. But only my arms are under the machine. I keep the parking brake set and the motor at a high idle and make sure no curious kids (or adults) are around to do a "What's this do?" to the joystick! I also lift the mower deck and use a garden hoe to scrape off the underside of the deck. But really, if I need to actually work under the deck, I just roll it over to the garage wall so the rear wheels are near the wall, block the rear wheels and then just grab the front of the deck and lift if up against the wall. Its not that heavy.
