That's me. I've owned a tractor for a few days now and there's some things that I don't understand about driving my tractor... particularly how the transmission works. It doesn't seem to be covered in the manual, so I'm guess its stuff that must be common knowledge.
My tractor is a bit rare. Its an early 80s Ford 545 (and industrial diesel tractor). About 45hp, 2WD, FEL, 3-pt. hitch, about 8k lbs, etc. etc. 8 forward speeds, 2 reverse. Its the type that you cannot shift on the fly, but have to be at a full stop (again I'm not a mechanic and definitely a tractor newbie).
The main problem I'm having is the sometimes it just won't go. This mainly seems to be when the tractor doesn't have enough power to move. For example up a hill in too high of a gear. But it doesn't stall... it just sits there in gear. Do I have a bad clutch? Or is it supposed to do this? Sometimes even first gear isn't enough to move it at near full throttle. Or more commonly, I have no way to back up because neither of my reverse gears works. Obviously I need some basic education here. Can somebody help me out?
Also, how are these generally supposed to be driven. I assume it doesn't matter how fast or slow you let out the clutch? Does it matter what the throttle setting is when you let it out?
