Newbie BX24 questions/comments
/ Newbie BX24 questions/comments #21
mswlogo said:
So I guess there must be a curve that is shaped like and upside down U.
I don't think it's so much a curve as it's more that you're trying to operate the tractor in the wrong range.
Low = operating range.
Hi= road gear and transport range;) .
I had it in low range. But I didn't know more pedal was less torque.
/ Newbie BX24 questions/comments #23
That was the way it was explained to me about more gas, less torque. I guess it doesn't shift internally the same as you're used to in a car.
It takes some getting used if you never had one before. I got about 30 hours on mine. It does have a few weak points, but as far as a tractor goes, it will get the job done. Just like with anything else, it just takes time to use properly.
There is a lot of useful information on this site, more than I ever thought possible. I've already learned not to screw up some things by reading what others have done. But I have still managed to hit a tree when cutting grass when the FEL was on. BTW, you're better off with all the attachments off when cutting grass. It is a lot easier, and not as bouncy. One good bounce can send you rolling.
/ Newbie BX24 questions/comments #24
You're better off with all the attachments off when cutting grass. It is a lot easier, and not as bouncy.
megaboz.
I've never mowed with the FEL or BH removed.
I have a lot of large open areas to mow so leaving the BH and FEL attached is not a problem when mowing with the BX23.
For the tighter areas I can use the BX1500 with just a 48'' MMM on it or the CC GT2554 with the 54'' deck.
Hopefully the CC won/t be around much longer.
I don't find the BX23 bouncy unless you are going at a high rate of speed.
/ Newbie BX24 questions/comments #25
megaboz.
I second this.
It only took me one time to realize that when finish mowing w/my BX23 w/the FEL & BH mounted there were no positives and far too many negatives to ever do it again.
It only takes 10 - 15 minutes to reconfigure a BX TLB into a very good finish mower. As good a finish mower lawn tractor as any made.....
3-Stage Forklift Mast with Forks (A59228)
3-Stage Forklift...
UNUSED FUTURE MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED FUTURE MINI...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
