newbi
/ newbi #1
aquafarmer
Angels Camp
Kioti LB2204
Hi all, I am in hopes that this site has some good info as I need to get a Kioti LB2204 up and running very quick not sure just what's going on with it started just fine before lunch now not even a click from starter..... i have been a mechanic, contractor, electronics tech, and most recently a computer tech, So I have a very broad base of experince....We just bought this place after losing computer bus to econ and health....now strating an Aquaponics farm.
/ newbi #4
Welcome to the TBN forums from Missouri.:)
/ newbi #5
Your problem sounds pretty minor (famous last words!). I would start at the battery checking for correct voltage and then check all connections for loose or corroded wires. Probably just a bad ground at your battery.
Welcome aboard and good luck troubleshooting.
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1996 Sunflower 1543-38 Folding Disk (A63118)
1996 Sunflower...
1000 Gallon Tank (A62183)
1000 Gallon Tank...
