Mark @ Everlast
Advertiser
As far as ESAB, yes, that is what I've been told as well. I own ESAB and have been told by a well known remanufacturer of electronic welder boards, that ESAB refuses to cooperate and supply parts. Now that has been a while back, but it sounds like since they've ceased production here in the US, it is nothing but a stripped down marketing company bent on acquiring other companies, stripping them down and cheapening up their product line. Giving a look at some of the latest Victor torches yesterday, I was shocked at how far down they've gone. The edge regulators that I have to deal with on a daily basis are deplorable. Hard to read gauges, with constantly sticking gauges, and won't fit a normal acetylene cylinder without hitting the fitting and hose on the top of the tank, when mounted. Also they cannot be used very easily for brazing or welding because of the oxygen markings are so imprecise that you simply have to guess where lower pressure settings required by the process are. The gauges are set so far in the black bezel, that you have to nearly shine a flash light on the gauges to see them. And for some reason, the PSI readings are printed over a medium gray marking which makes it that much more difficult to read.
