New welder advice.
/ New welder advice. #1
Kiotikarl
Quebec Canada
2010 Kioti ck30 gear
Hi everyone!
I need advice on the purchase of a new welder. I am looking into either of these brands; Miller shopmate 300DX,Lincoln Power Mig 350MP, and Esab Multimaster 300, that's what is available around where i'm from. I currently have a Millermatic 211MVP mig, Lincoln SP-100 mig and lincoln 225 ac/dc buzz box. I intend on keeping the sp-100 and selling the other two.
I have no problem mig welding, stick welding is another story but i get the job done, even though it's not always pretty:(. I have no idea of tig welding welding. What i mainly do with the welder:
- Utility trailer building
- Auto body repair
- Anything i can make for my tractor
- Steel welding
Anyhow: i intend on making my own gooseneck trailer, so i need more powerful than my 211. Would a multi process welder (mig/stick/tig) be overkill:confused:
Any advice is more than welcomed.
Karl
/ New welder advice. #2
I've never run any of these machines, but I would lean towards the ESAB with the variable inductance. I had a 1980's Linde with it, it is amazing the control you have over the puddle with it.
/ New welder advice. #3
We had a Power MIG 350 at work and several Multimaster 260s (in 2007).
The ESABs are easier to set up and run well, but I'd buy the Power MIG and if I had the money later I'd get the Python Plus push-pull setup for welding aluminum.
The Lincoln takes the usual "Tweco style" consumables.
The ESAB is probably the best bang for the buck for what you want to do, but consumables tend to be expensive (shop online, Scott-Gross are sorta reasonable).
I think you'd be happy with either for your expressed use.
Thanks, waiting for the quotes, gonna shop around a bit cause these things aren't cheap. Meanwhile these are some things i built with my 211 to pass time:thumbsup:. photo tel 2 008.jpgphoto tel 2 010.jpgphoto tel 3 029.jpgtrailer 6x10 003.JPG069.JPGtrailer 63x123 006.JPG
/ New welder advice. #5
I have an ESAB MigMaster 250. It'll run circles around it's competitors. They made it a long time without many changes. The multi master 260 is the same way. They got it right the first time and it kept up with the times.
/ New welder advice. #9
All things being unequal, I'd go with the one with the best/local support.
RC
2008 Mini Cooper Hatchback (A66738)
2008 Mini Cooper...
2016 BIGHORN 5th WHEEL (A67714)
2016 BIGHORN 5th...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2002 Bombardier Evinrude 90HP Outboard Boat Motor. (A66738)
2002 Bombardier...
2014 TEXAS PRIDE GOOSENECK TRAILER (A67714)
2014 TEXAS PRIDE...
