New truck #@$%@#&
/ New truck #@$%@#& #101
df - did you mean older than 1997 ? Either way, I find that a bit surprising.
Good catch. CA did not require smog inspections for diesel PUs and cars until something like 15 years ago. If
your vehicle is older than 1997 model year, then no inspection required. CA still has no smog inspection for
motorcycles, which is surprising considering CA is the world leader in emissions regulations.
This is from memory, so others are welcome to peruse the ordinances and correct me on any details I got
wrong.
/ New truck #@$%@#& #102
Or my '93 and '97 Volvos and our '97 Dodge 1500...
Aaron Z
Yes, there's always exceptions. Overall though, rust kills most vehicles; the only reason that my '04 Ranger isn't in the junkyard is because I stop driving it at the first snowstorm. Springs,shackles, shocks, and brakes have all be replaced because of rust. I'm looking for an affordable ton truck down the road a few months and it will be worthwhile to go to Az and have one shipped back. I was looking at Texas or Georgia, but last year's flooding nixed that idea.
/ New truck #@$%@#& #104
Good catch, Moss! :thumbsup:
/ New truck #@$%@#& #105
I work at a Dodge dealer and I'm a Ford guy through and through. However the Ram trucks are very reliable and do not have many mechanical problems. The ZF8 speed auto transmission is stout.
What I'll say about new GM trucks is prepare to pay out the nose on oil changes, 8 quarts 0w20. Where I work its $10 per quart on synthetic oil.
If I was 20 years younger I would look at that Cummins with a manual tranny and the PTO option.
I can't justify 50k for a truck for what little I will be using it.
/ New truck #@$%@#& #106
I would too if I could afford the payments. Downside is, they detuned the engine to 610 or so ft/lbs of torque with the manual transmission, only because they don't want to put in a good clutch. You get something like a Southbend clutch in it, you could run a 900ft/lb tube without burning up the clutch. Back when I was a kid, only way you could get the high output engine was with a manual. Man how much stuff changes I 20 years.
/ New truck #@$%@#& #107
Rgds, D.
Correct. Even California doesn't inspect my '97 F350 diesel, though it had emissions requirement stuff on it new (catalytic).
/ New truck #@$%@#& #108
It woild need to pay for itself, but 20 years ago I would have found a way. Take care of it, only use it when I needed a big truck and it would last me a lifetime.
/ New truck #@$%@#& #109
No A/C in TX, or just lacking duplicate controls ?
Rgds, D.
It has AC, in fact it blows really cold :thumbsup: It just doesn't have climate control where you set a temp and it modulates accordingly. I find my self constantly bumping the manual control up or down on long drives.
/ New truck #@$%@#& #111
I do that anyway. I tend to use maximum cold setting and adjust the fan speed accordingly.
/ New truck #@$%@#& #112
Me too. My first car with AC was a 1973 Datsun 1200 with an add-on ARE system the best I remember. It actually had a thermostat that kicked the AC compressor off and own. I was using it a lot because after getting out the Navy I started to college in Abilene TX so it was a long and sometimes hot haul from KY. To save the power for the wheels I got in the habit of turning the Temp to Min when going up hills and to Max when starting back down. :)
This 2010 F150 we just picked up the AC is only blowing hot air on the driver side. At least it is cold for the wife who was a bit hot over me buying yet another vehicle. :)
Amazon shipped the $26 fix last week but I am not looking forward to installing it but at least it seems to doable without removing the dash per youTube.
It is issues like these that make these fancy trucks cheap before their time because it is $1000+ job at the dealers I read. I am going to replace the one for the passager's side too since it is the easy one and hope these Ford improved door motors are actually an improvement.
In cases like this I wish for the old sliding cables to open doors in the dash. :)
/ New truck #@$%@#& #113
A former coworker refused to run AC OR open his windows because it would hurt his gas mileage. I saw him one hot day after work heading for a long trip downstate in his little 2WD Nissan pickup with his windows rolled up, no shirt, and even from a distance could see that he was covered in sweat.
He's probably a billionaire now.
/ New truck #@$%@#& #114
My wife sorta does that too and it drives me crazy. She doesn't set to Max Cold (or Hot in the winter), just, say 68° and then manually adjusts the fan. It's always to hot or cold and she keeps adjusting the fan rather than letting the computer just do it for her. And she doesn't want me to touch her controls... The other day it was uncomfortably warm even though it was set at 68° so I asked if we could cool it down. She said Sure but didn't do anything, so I pressed the Auto button since 68° would be plenty cool if that's what it actually was. 30 seconds later, when it wasn't "cool" yet, she cranked the fan up to max.
Granted, not all auto climate controls work all that well, but most fairly modern vehicles I've driven work pretty acceptably. The one on my '15 Ram works great.
/ New truck #@$%@#& #115
That's funny. I have a friend who drives his vehicles with the A/C on in hot weather, but insists on keeping the system on recirculate all the time. Even after the air has gone stale inside from occupants breathing.
There was an interesting article in Motor Trend recently that discussed air quality inside vehicles today. Tests have shown that modern vehicles, which are sealed quite well, can have high CO2 levels inside in as little as 25 minutes with one occupant. That is with the air controls on recirculate. For 2 occupants, it is half that time. High CO2 causes drowsiness and higher risks of a crash. Some new vehicles will have CO2 monitors as a result.
Ya can't trust those vehicle owners with control of their HVAC systems!
/ New truck #@$%@#& #116
wrong.
The provincial govt that Ontario Canada just got rid of struck me as trying to out-Cali Cali, when it came to appearing green.
Ontario goes back to 1988 for testing, gas and AFAIK diesel.
Rgds, D.
/ New truck #@$%@#& #117
If Work pays the bills on repair it won't matter to you, but I picked up this wisdom from a pro-wrench friend of mine...
If you have AutoTemp control, and plan to keep the vehicle a long time, take it off auto, and set temperature manually. Constantly adjusting that blend door in Auto mode, usually leads to the door/linkage breaking over time.
My friend made good coin off of people who used Auto mode..... lots of hours involved yanking a dash to ReRe one small blend door...... of course, while you're in there, you don't just change one actuator, but all of them. Labour is the (relatively) expensive portion of the bill....
Another good example of why I don't like added complexity in most systems, when owning beyond the 100% covered warranty period....
Rgds, D.
/ New truck #@$%@#& #118
I always liked the Tshirt "Go Lemmings, GO"......
I used to work near the main Toronto airport. Stayed later at the office, clearing stuff up one night, instead of sitting in traffic. Left late, the main highway was virtually deserted - crappy, stormy, late-Fall cold and rainy evening. I passed (2 lanes over) a very slow moving, very late model high-end BMW (7 or 8 series) - the car windows looked like a humid greenhouse, with all the moisture running down the INSIDE of the windows.
Cold damp weather up here (and throughout Winter), some people use ReCirc when they definitely shouldn't.
Though.... to be fair to the Bimmer driver, they might have known exactly what they wanted to do, but had not yet taken the 3 week course needed to run the iDrive interface :cool:
(Sorry about drift OP..... but it connects in my mind in terms of needless complexity causing collateral problems....).
I rarely drive anything with the windows completely shut. But, I don't drive the SouthWest.....
Rgds, D.
/ New truck #@$%@#& #119
I was leaving work and saw this, I just laughed.
It’s a contractors 2015 or newer F150 XL single cab 8ft bed 2wd (no 4x4 graphics) next to my 95 F350 XL dually flatbed single cab 9ft bed. My hood is a hair lower than the F150 and bottom of windows are about equal.
/ New truck #@$%@#& #120
View attachment 562143View attachment 562145
I don't doubt it's a 2wd truck, not all trucks had the 4x4 decal on them. My dad had a 99 F150 XLT that was 4x4 but lacked the decals.
