new trouble
/ new trouble #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i just rebuilt my dump cyllinders on my loader ..with this boards help.... but now it will leak down quicker than ever ,,,i was told it was the valve it self...has anyone ever rebuilt one of these...it is a massy 1525 loader on a 1540 tractor...thanks again for your help bruce
/ new trouble #2
First off, have you been using it after the rebuild? If not, there could still be air left in the cylinders. To get it out, you need to fully extend them and HOLD the lever extending them more for a count of 5. Then retract fully and HOLD the lever retracted for 5 seconds. Repeat that cycle 5 times and it will be fully bled out.
If it is still drooping, double check for any leaks and if you don't find any, it's probably the control valve. It may be the kind with o-ring seals. Easy and cheap to replace them. Or it could be a worn spool and cylinder. You will probably have to replace the valve if that's the case. I would be VERY suprised if that was the case as they normally last a LOT longer!
/ new trouble #3
Lift the loader off the ground,. raise bucket to mid position and unplug both the couplers for the dump/curl circuit. If it still leaks down its a ram problem,.. if it doesn't its a valve problem.
/ new trouble
ok i tried unhooking the hoses ..it still leaks down..could i have done something wrong ??? i put the cylinders back together just like it came out ...help i need my tractor ..i use it everyday to make a living... thanks for the help bruce neal
/ new trouble #5
Take them both back apart. It sounds like you may have assembled backwards, pinched/tore a seal, etc. If all that was good, you may have wrong seals or there is a scratch in the cylinder that is allowing flow.
jb
/ new trouble #6
Bruce, you probably tore a piston seal during assembly. This is common. Some piston seals are a real pain to install without tearing them up. Get new seal kits, disassemble, and post pics of the old piston seals so that I can see what style they are. I can then advise you on the proper assembly procedure. Shoot me a pm when you post as I don't check in as often as I used to.
Also, IMHO, if you need this piece of equipment to make a living, I would bring the cylinders to a shop, get them done once, get them done right. I pressure test every rebuilt cylinder for 15 minutes to make sure everything is okay. Any good shop out there will do the same.
Andy
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
2019 GMC Terrain, AWD (A62679)
2019 GMC Terrain...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
