Tractor Sizing New Tractor Question
/ New Tractor Question #1
spivey44
Atlanta, Ga
Kioti CK27
Currently on a Kioti CK27. Looking to upsize. I am considering the DK series. My implements are all 60 inch (flail mower, box blade etc.
The DK series Kioti are designed to handle I believe 72 inch implements. Any problem running a 60 inch mower on the larger tractor? Both tractors are Cat 1. I have been told I "should" buy larger mower as the 60 inch will be "inside the footprint"of the DK and therefore tires will compress grass resulting in a poor cut?
Any thoughts on this?
/ New Tractor Question #2
You won't have any problems running smaller attachments...but you won't be taking advantage of the increased PTO power.
You'll likely upgrade your attachments as time goes by...
/ New Tractor Question #3
You are always compressing the grass with the tires before you mow it. But without covering your tracks, you are compressing it a second time.
A work around for that is you can always use your sway links and offset the flail to the inside. That way, you cover that track.
All-Aluminum Timpte 720 Trailer (A63118)
All-Aluminum...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
16ft Cattle Panels (A64047)
16ft Cattle Panels...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
